Old 20-10-2004   #1
Rear disc pads.
Does anybody know how to change the rear disc pads on a 1.6 Stilo fitted with Bosch brakes?
I have changed disc pads before without problems, but I cannot seem to get the piston to go back into the caliper. I presume you have to do something with the handbrake mechanism (which works the disc pads and not seperate drum brakes as on previous cars I have worked on).
Any help would be appreciated.
Chris
cmk12342000 is offline Reply With Quote Quote
Old 20-10-2004   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Rear disc pads.
i think the stilo has wind back pistons on the rear.you will need a tool to wind back the pistons.sykes pickivant do one.
Old 20-10-2004   #3
Re: Rear disc pads.
must be the same as the saabs then. you can make a tool with a bit of plate and 2 small bolts to wind the piston back in.
DOG is offline Reply With Quote Quote
Old 21-10-2004   #4
Thumbs up Re: Rear disc pads.
The wind back tool required is NOT the general type one of the calipars has a left hand thread and the other right hand thread the Fiat tool comes as a two part tool kit
Ned is offline Reply With Quote Quote
(S) Updated price list 21/04/2004 Body Stylist Punto (Mk1) 30 09-04-2005 17:02
(T) rear axle thefishdude Punto (Mk2/2b) 0 09-10-2004 22:42
(T) Rear Disc Brakes.... bad_boy_racer Cinquecento / Seicento 25 03-07-2004 20:04
(G) DJ Bucho is back DJ_Bucho Cinquecento / Seicento 19 14-05-2004 18:41
