Has anyone experienced this problem before? Today I took my Abarth Stilo for it's MOT and it failed. It failed on 2 indicator bulbs one is in the front passenger side and the other is in the rear drivers side cluster. so I struggled to get to the front indicator bulb only to find the bulb was fine. So I dismantled the rear light cluster and found that bulb was OK. So I thought it must be a fuse but I have been unable to find a fuse that protects only these 2 lamps. These 2 lamps do not work when setting the alarm or using the indicators or using the hazard warning lamps. Any help in tracing this fault would be happily received.
