Had a recent problem with my 8v JTD lagging at low revs, then pinking followed by a cloud of smoke. EGR sprang to mind, so I removed and cleaned it this morning. Took it for a test run and all was great untill about 15 miles into my drive. When the engine was hot the problem returned with a vengeance. Now runs even worse. When I removed the solenoid, I noticed that movement was very restricted. No matter how much I cleaned (with carb cleaner) WD40'd it and cleaned again, it still felt 'crusty'.
Does the solenoid work on an open/shut basis or is it a gradual thing?
Will I be buying a new EGR valve?
Any help would be appreciated.
