Old 16-12-2008   #1
Sei + coupe = poor
h2ypr's Avatar
h2ypr has donated!
Stilo electrical problem + warm starting problem
Driving to work today and although i have the heater on, i get a cold blast of air across my neck...
Look across and the passenger side window is completely down...
Try to raise it via the control panel on drivers side and no response. Lean across and manage to raise via the passenger side. Happens several other times on the trip with varying results from the passenger and drivers side switches.
Get to work and i think its the drivers side control panel. Pop it out and start wiggling the wires... hear clicking from the passenger side. Not sure if its the control panel itself or the loom.... anyone had this before?
Also, notice when the car is warm it struggles to catch and this results in having to hold it for longer to get it to start... any ideas? Rarely happens when cold.
Ross
h2ypr is offline Reply With Quote Quote
Old 16-12-2008   #2
Sei + coupe = poor
h2ypr's Avatar
h2ypr has donated!
Re: Stilo electrical problem + warm starting problem
Is the lack of replies because no0one knows or because its just not that common a problem or cause no0one likes me
Only day i have for looking at this is thursday morning, so really looking for an idea on how to attack this!!
Ross
Old 16-12-2008   #3
Starting sounds like typical crank sensor problem, have a search, there is a massive thread on it
Moire black 5dr Stilo 1.9JTD [FONT=Arial]17 inch multispokes and a skyroof[/FONT]
kris lee is offline Reply With Quote Quote
Old 16-12-2008   #4
Sei + coupe = poor
h2ypr's Avatar
h2ypr has donated!
Oh right.....
How difficult to replace? Any idea what the thread is called? Thanks.
Ross
Old 16-12-2008   #5
Super LOL!
Stu DemonD's Avatar
Trader Rating: 1
Stu DemonD will never be forgotten
Stu DemonD has donated!
Jigsaw: Chess Pieces Champion
Quote Originally Posted by h2ypr View Post
You bumped this after 5 hours! I suggest next time you give people a chance to reply, ok
See you next Tuesday
Stu DemonD is offline Reply With Quote Quote
Old 17-12-2008   #6
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: Stilo electrical problem + warm starting problem
Firstly check the plug situated on the front door frame..lift the round clip and pull ..check for bad connections and refit..that was my problem when it happened to me.. other than that ..when the appropriate door switch is pressed [left or right] the appropriate window motors receives power to the relevant door node which receives the command [open/close] from the switch on the door panel..the door node is protected by a special fuse housed in the under dash fuse unit and controlled by a relay also in the unit.so check these out and if no success is got then a diagnostic test of the circuit will be needed[I'm sure Decks can help you with how to do a circuit test] hope that help mate..
Sorry for the late reply..
PNL is offline Reply With Quote Quote
Old 17-12-2008   #7
Sei + coupe = poor
h2ypr's Avatar
h2ypr has donated!
Quote Originally Posted by PNL View Post
Thanks dude.
Didnt happen today but no illumination on the control panel. I'm sure its the control panel...have ordered a replacement panel, and asked for wiring to be included so hopefully its one or the other. Seems like bad connection inside the unit or the wiring to be honest.
Ross
Old 17-12-2008   #8
PNL
Banned
PNL's Avatar
PNL has donated!
Disconnect battery and reset ecu works as well.. if all this doesnt put you off stilo ownership nothing will and you are hard core member of the stilo massive..
Old 17-12-2008   #9
Sei + coupe = poor
h2ypr's Avatar
h2ypr has donated!
Noone owns a fiat and expects it to work all the time...
Ross
Old 17-12-2008   #10
Oh right.....
Ross
Just search crank sensor fault and i'm sure it will come uo!!!
Old 19-12-2008   #11
Trader Rating: 3
ycming has donated!
Ross
Easy fix mate, buy another sei or cinq. sell the stilo sorted!!!
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 19-12-2008   #12
Forum Moderator
T14086's Avatar
T14086 has donated!
check A pillar loom connector, not sure about crank sensor though more like voltage problem if you need to crank it longer?
Old 20-12-2008   #13
Sei + coupe = poor
h2ypr's Avatar
h2ypr has donated!
Quote Originally Posted by T14086 View Post
Was checking it last night again, as it was playing up badly yesterday. Its definately the wiring as i've replaced the control unit. Moving the wiring causes the window to either click or actually move. I reckon the constant live for the illumination is touching the passenger side wires. So i'll probably need a new loom for that section. Anyone any idea of how long that section of wiring is?
As for cranking problem, i reckon its a fuel issue. Possibly dirty fuel filter.
Ross
Old 20-12-2008   #14
Forum Moderator
T14086's Avatar
T14086 has donated!
just door loom, about 45 ish & not hard to fit.
Old 22-12-2008   #15
Sei + coupe = poor
h2ypr's Avatar
h2ypr has donated!
Superb!!!
I'll strip the door down tommorow and have a check, but if i cant get one from a scrap car, i'll nab one from fiat!!
Thanks for your help people.
As for the starting problem... occasional "engine fault" message appearing at start up and then disappears immediately. Crank sensor looks like its on the way out
Ross
(G) Starting problem Stilo 1.2 850kd Stilo 7 11-04-2008 11:12
(T) Warm Start Problem kegg Punto (Mk2/2b) 0 24-09-2007 20:24
(T) warm start problem Dave lee Cinquecento / Seicento 5 19-11-2006 21:59
(G) warm start problem with uno 1.7 Shafiq Ahmad Uno 2 27-02-2006 16:36
(T) Problem starting when warm (Bosch SPI) cammy Uno 3 30-06-2003 16:28
