- Nov 3, 2008
- 118
- 25
my cars currently in a garage as the car wont go into gear due to selespeed fault.
heres some background see if you guys have any ideas,
no problems untill at the mot centre of all places, now i think when the tester slamed the bonnet i heard a warning beep,
next thing i know i had the return to dealer warning and car wont select any gear (engine will start however)
i left it about 10 mins, had a look about, checked the resovoir, then it started, no other faults!
then last night going over a speed bump, i got the gearbox warning again, but it was still drivasble and went after about 30 seconds.
later in the evening after being parked up for a while i went to start the car and same as before, no gear selection.
(no signs that the pump is priming upon opening the door BTW)
i left it a while, had a look about, opened the selespeed bottle, closed it, then it started!
after about 10 mins i had another look, now i think i placed my hand over the breather pipe/cap and pressed down while looking about, i then heard the fault ding, and error was back,
i then gave the resovioir a few subtle slaps :devil: and then i heard a warning beep, the dash said something like loose connection, i also noted the gear selection numbers in the bottom left was now replaced by the date, i gave it another slap :slayer: and the loose connection warning had gone, but the normal gearbox error still there.
any ideas?
could my actions of blocking breather pipe caused it to pack up?
possible loose connection? judging by the error on speed bump and me slapping it?
its at quite a good local garage but theyve never done a selespeed before.
any ideas?
