Non Starting Stilo
Ive pasted this from a previous thread which I think has gone stale as i have had no replies and it has gone quite a bit of topic from the main thread I posted to.
Yesterday evening after an afternoon of snow and cold I left work, jumped in my car and nothing. Dash showed EBD failure which most people say is the battery. Called out breakdown and it still wouldnt start with the jump leads from the breakdown van. The guy proved fuel was getting to the engine no blockages in air supply. I had cleaned the MAF and the turbo body at the weekend so no issues there. I had put a J cloth over a broken vapour trap pipe so no crap going into the turbo. When trying to start got the occassional flicker of the glow plug light and injector sysmbol before it gave up trying to start. The mechanic said everything was in place and there is no reason for it not to start so he assumed the fuel was either not getting through the injectors or not being atomised properly. I got the train home. Car taken to garage today and I await their findings. Hope this is the root cause of the judder/ low power I have had laterley and the car will come back as good as new till the next thing happens
Ive had quite a few problems with this car but garages have advised me that most cars these days can have problems due to the complex nature of the technology now used. The new Mondao has been singled out by one garage as very unreliable in his opinion. I have had new steering column after it failed when jump started, new clutch which failed after 3 months and took the gearbox with it, new gearbox and another clutch. two new front springs. Three bonnet release levers as they just fall apart, all the plastic protection has broken of the underside, skywindow jammed (fiat said bring it in and well try and fix it, this forum told me just hold the switch in and it resets. Phoned local Fiat back and told them what to do next time!), plus all the usual items that wear out - brake disks and pads, tyres regularly, and light bulbs. Despite all this I really like the car and when it works its absolutley brilliant. I'm expecting the rear suspension to be next as i have done 124000 miles in it and am adding 130 a day weekdays. After this last thing I have to admit that i may have to let it go if this continues but what will i get instead of it? There's nothing on the market that appeals to me. I like the new Panda but its too small. A bigger version would be great so i guess the new Multipla is the nearest thing.
Well it took two weeks for the garage to get my car to start. They said they had found part of the J cloth that was covering the vapour trap pipe in the inlet manifold. I was still getting glow plug message but thought this would clear itself after a few starts. It took some starting after collecting the car and leaving it outside work a few hours. Once I got going the car really flew and I thought everything was OK. I should have known better! Started getting the drop in power problem the next day and still the glow plug warning plus ABS and occassionally EDB. Travelled about 200 miles in it in three jouneys but on Saturday morning having loaded up with baggage and family the thing wouldnt start. Engine turned and I got the occasional splutter of a start which died after a few seconds. I would have thought that having turned over a couple of times the glow plugs wouldnt have been an issue but maybe i'm wrong. I ve started to think this is a genuine message and am going to get the multimeter on them when a get a minute and try spraying the connector with contact cleaner.
Ive recently had a new gearbox and having read about a gearbox earth connector wonder if this is related.
Today I had a fan heater warming the engine for about half an hour but it still wouldnt start and I drained the battery.
Do you guys out there think I am on the right track with the glow plugs or could this be more debris in the inlet manifold. Fuel is definatley flowing so what could this be? Around £2500 has been spent on this car in the last few months so its getting to the point where It'll have to go if it doesnt get sorted soon!
