Can someone please tell me where to find the reversing light switch on the gearbox. The lights or rear wiper dosn't work, checked fuse ok. Cant find the switch.
I changed mine last week as had the same plus no parking sensors.
If it is a JTD then the switch is on the right hand side of the gear box when viewing the car from the front, ie at bonnet.
Jack up the n/s, remove wheel, remove undertray and n/s plastic engine cover. Now you can easily get to the switch with a 19mm recess ring spanner. Just unplug the connector and unscrew the switch.
