Look, I'm not saying this just to **** you off, or to wind you up. I'm simply saying, I know, for a fact, that you will not gain 30bhp from an air filter.
Simple as that.
I've worked on cars & bikes, built and tuned engines for the past 15 years. I done alot of work on my old twin turbo Supra with regards to airflow into the engine. And even with it fitted with a pair of rather large hybrid turbo's (RS500 spec), the stock box and filter were still easily capable of flowing enough air to the engine. I experimented with a few different setups and none gave any improvements over standard, all work was done on a dyno.
Car manufactures spend millions on engine development. Do you really think they would chuck an airbox and filter on that was running at its full potential with regards to the engine?
The ONLY time I would ever think of replacing the airbox or filter is if I was going racing. You just have to look under the bonnet of a BTCC car and see they all use an enclosed airbox, as do pretty much all race cars. Simply because you get better power.
Cold, still, dence air. That it what you want to aim for. A cone filter sitting on the end of a bit of silicone pipe is not going to give you this, and therefore give you no power advantage.
