![]() | #1 |
Posts: 1,240 Thanks: 35 Trader Rating: 0 ![]() | 4 wheel alignment at fiat right went to find out about 4 wheel alignment today, £90 plus vat, are they taking the pee?? then i got a load of waffle off a guy who said it allows them to adjust the camber of the fronts, whats he on about??? Tow i can understand,,,, but camber,,, errrr its a fixed camber mate..... is it really a 2 hour jub too just to set trackrod ends?? if 90 quid is the going rate i'll stick with manual type that most garages have for 20 quid...
__________________ ![]() |
![]() | #2 |
Posts: 83,472 Thanks: 1479 Trader Rating: 10 ![]() | Re: 4 wheel alignment at fiat
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” |
![]() | #3 |
Posts: 1,240 Thanks: 35 Trader Rating: 0 ![]() | Re: 4 wheel alignment at fiat ![]() does anyone know of anywhere witht the 4 wheel setup that isnt fiat themselves??
![]() | #4 |
Posts: 83,472 Thanks: 1479 Trader Rating: 10 ![]() | Re: 4 wheel alignment at fiat i only know one down here, was some one else that posted up another a few weeks back cant remember where that was though ![]()
![]() | #5 |
![]() | Re: 4 wheel alignment at fiat Try www.protyre.co.uk They only charge about £13 and you get a nice printout. It was so cheap I had mine done twice - once before spring change - and once after ![]()
__________________ ------------------------------------------------------ Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic |
![]() | #6 |
Posts: 2,831 Thanks: 135 Trader Rating: 2 ![]() | Re: 4 wheel alignment at fiat There is a camber adjustment option in the top mount, not visible until you pull out the whole thing - but it is worthless as you can't adjust camber on the hub... Coilovers often have camber adjustment visible from the engine bay at the top mount, but still, the top mount of the Stilo is pretty strange, as it is not fixed to the bodywork at all. It is just pressed up there and with a nut holding it so it would not fall out when jacking up the car (or jumping). M.
__________________ jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts. member of the 5-door massive attack. |
![]() | #7 |
![]() | Re: 4 wheel alignment at fiat One good thing that came out of my spring changing saga is that whilst the car started off at near to end of tolerance on camber (presumably out of factory), it's now (after changing springs twice) well within tolerance ![]()
![]() | #8 |
Posts: 1,240 Thanks: 35 Trader Rating: 0 ![]() | Re: 4 wheel alignment at fiat Cheers for the advice guys!, just got back from national tyres, tracking set... it was towing out -7 degrees , drives dead straight now, no pulling to one side and steers ten times better! and 4 wheel alignment for 25 quid!,,, bargain and in regards to the rear torsion beam he checked that too.. said it was fine... the axles are set in relation to the chassis, not the bodywork! so all good!
__________________ ![]() Last edited by Steely; 21-06-2008 at 13:05. |
![]() | #9 |
Posts: 2,831 Thanks: 135 Trader Rating: 2 ![]() | Re: 4 wheel alignment at fiat Morten.
![]() | #10 |
Posts: 1,164 Thanks: 35 Trader Rating: 3 ![]() | Re: 4 wheel alignment at fiat my rear passenger side is out, and theres no adjustment on that, and its pretty much screwed the alignment for the rest of the wheels ![]() |
![]() | #11 |
![]() | #12 |
![]() | Re: 4 wheel alignment at fiat i got mine done at north easter tires in york, they also have a new one in knaresborough, was about £25 i think and it has a 1 year warranty on it so i can go back and get it done when my new tires are fitted ![]() (p.s. ben you need new sig with new wheels) ![]()
__________________ ![]() ![]() ![]() ![]() ![]() ![]() FANCY A BUM? ![]() |
![]() | circolo | Bravo / Brava | 2 | 27-02-2008 14:29 |
![]() | Kelv27 | Punto (Mk2/2b) | 2 | 23-04-2007 16:11 |
![]() | stilosporting | Stilo | 10 | 18-08-2006 18:38 |
![]() | Streaky | Stilo | 7 | 14-08-2006 21:35 |
![]() | twincamms | Stilo | 5 | 10-11-2003 21:58 |
