re: JTD - GSR induction & Red-Dot remaps!
did you guys see mine before i cleaned it?
Yes I did and very dirty. Probably 20% reduced in size due to crud build up inside. I imagine the rest of the manifold is the same. One day, when I have time, I'll take it off too.So, I presume you removed it from the manifold to clean it?
Just how dirty was it?
No. Only petrol engines have a throttle body.throttle body?
It seems you are experiencing turbo Lag
I can only explain this by fault of the ECU not understanding what this extra information is at this point and the advanced timing is going out of sink of the fuelling. (I dont have a clue what this means as i said before im not too up on how engines work i am just deriving from facts) anyway this could explain dirty sparks in my old Punto.
Surely the only relevant sensor is the MAF (and not forgetting temperature :chin... so cheat the signals and you have a sort of solution.
Yes; but MAP is post turbo - so a bit indirect from induction :chin:maf, map, overboost valve, boost pressure sensor?
Also would a induction kit be of any use on a standard jtd.:chin:
Mine was rolling roaded pre-GSR kit, then with GSR kit and then with GSR kit and remap. The induction kit alone was worth a couple of BHP but a much more dramatic raise in torque
