While im on here this morning ranting on about my Abarth, here's another tech question.
Seem to have a fault with ABS and auto drive, i get ABS TCR back to dealer fault coming up on the dash but only between 1 and 5 miles after i set off ( is this normal)
So then there is no auto shift up box i have to drive with the paddles.
Now the only thing i have done before this problem came up was change the steering rack and repositioned the abs sensor wires in there grommets as they looked a little strained, could moving them have cracked a wire ?. If i switch off and re-start its the same sometimes auto works sometimes not but no dash fault till after 1 to 5 miles.
Would a ECU fault check tell me which sensor has gone down.
Cheers again
Cheers again
