im Axle Specialists
Old 05-06-2008   #1
Broken Key fob
My Key Fob is broken, it's nothing major, just very annoying.
The problem is the key no longer 'blips' out (is there a technical term?)
I do have the annoying habit of playing with it, and presume it has snapped some sort of spring inside.
It still goes back ok, but i need to pull it out when needed.
I have the spare key, but want to fix it if possible.
Any body had the same problem?
2002 Abarth- Totally original
jpholroyd is offline Reply With Quote Quote
Old 05-06-2008   #2
Serbia
Re: Broken Key fob
It should be easy to open it and reveal the mechanism - I think it is also an access to the battery for remote. I'm sure that you can improvise some solution, especially if you have spare key.
nidza is offline Reply With Quote Quote
Old 05-06-2008   #3
Re: Broken Key fob
I have an old stilo key you can have to take the mechanism from if you need.
john55 is offline Reply With Quote Quote
Old 05-06-2008   #4
wing1200a has donated!
Re: Broken Key fob
Very easy to open. Pry fiat badge off. Remove battery. Undo screw that can be found under where badge was. Pry cover apart. Within the cover the blase sits on a spring. It is probable that the spring has slipped causing tension loss. Simply rewind the blade until there is tension and replace cover. Replace screw, battery and badge after ascertaining tension is satidfactory.
wing1200a is offline Reply With Quote Quote
Old 06-06-2008   #5
Re: Broken Key fob
Thanks for the kind offer John
Took the fob apart, after following Wings advice, only to find a tin bit of plastic has snapped off
I think some super glue should solve the problem
Thanks for the advice
Old 06-06-2008   #6
has pooped his pants
Greggers's Avatar
Greggers has donated!
Re: Broken Key fob
Quote Originally Posted by jpholroyd View Post
I had the same thing on mine as well. Seems to be a weak point in the key
I ended up getting a cheap second hand fob off ebay and swapping out the gubbins inside
'02 Stilo Abarth 5 Door
18" OZ Wheels, Prodrive GP Suspension,
Brembo Gran Turismos, GTA Injectors, GSR & BMC CDA, Red-Dot Remap, Custom De-Cat Exhaust
Garage
Greggers is offline Reply With Quote Quote
(T) Key Fob Help Please samwich000 Punto (Mk2/2b) 1 06-06-2008 16:45
(G) key fob reddevil Ulysse 1 15-03-2008 20:06
(G) New Key Fob John1Fiat Scudo 1 22-02-2008 10:35
(G) Key Fob Poondash Punto (Mk2/2b) 2 07-10-2006 02:09
