Old 03-06-2008   #1
Fiat Stilo Judder when pulling off
Has anybody got an idea as to what could cause my nice Stilo to judder when i pull off? It doesn't happen all of the time, but most. I would say 50-60% of times when i pull off.
Sometimes it feels like it is worse when the car is cold/first started, but it sometimes happens when the car is warm.
The car is under a 12 month used car warranty, so i can take the car back. Just thought i would try here first!
Cheers.
04 Stilo, 1.4 16v 5dr
Sticking feathers up your butt does not make you a chicken
roboticgimp is offline Reply With Quote Quote
Old 03-06-2008   #2
has pooped his pants
Greggers's Avatar
Greggers has donated!
Re: Fiat Stilo Judder when pulling off
Quote Originally Posted by roboticgimp View Post
Cheers.
You might want to do a check on your coils. If one of them is one the way out, then it can cause juddering when pulling away.
The way to test a coil is to have the engine running and disconnect each coil in turn. If the engine revs drop and it struggles, then that coil is fine. If the revs don't change, then the coils packed up.
'02 Stilo Abarth 5 Door
18" OZ Wheels, Prodrive GP Suspension,
Brembo Gran Turismos, GTA Injectors, GSR & BMC CDA, Red-Dot Remap, Custom De-Cat Exhaust
Garage
Greggers is offline Reply With Quote Quote
Old 03-06-2008   #3
-~Moderator~-
a1ant's Avatar
Trader Rating: 1
a1ant has donated!
Hi mate,
Is it judder from the clutch/gearbox or misfire?
If its from the clutch then sounds like your clutch plate may be contaminated or damaged.
Alan
If you see a problem post, please click the report button
a1ant is offline Reply With Quote Quote
Old 03-06-2008   #4
popping out
dan-the-man has donated!
Quote Originally Posted by a1ant View Post
Hi mate,
Alan
sounds like something could have leaked onto clutch
dan-the-man is offline Reply With Quote Quote
Old 04-06-2008   #5
Its from the clutch, when it happens i have to do a combination of dipping the clutch pedal and/or over revving on pull off. Funny thing is it doesn't always happen. Spoke to Fiat dealer where i have the 12 month's after sales warranty but he couldn't guarantee it will be covered by the warranty.
Tried to tell me it could be wear and tear, to which i said the car is four years old and only has 25,000 on the clock! Wear and tear, he can bugger off!
Spoken to another Fiat dealer service desk and they said Stilo's have a habit of the Flywheel becoming faulty.....
I'll have to get it booked in at the dealers i suppose, hopefully its covered, otherwise i have to pay for them looking at it!
Old 04-06-2008   #6
Brain freeze
LoBsTeR's Avatar
LoBsTeR has donated!
Nothing to do with the flywheel. It will be the clutch when cold. Perhaps a difference in the ferous material that only manifests itself when cold and a bit damp.
This can sometimes sort itself out as the clutch wears the faulty material out.
Be cautious of any fluid leaks onto the clutch plate. This would have the same effect and could indicate a gearbox oil seal failure.
I think its just the clutch.
Stilo JTD 115 3dr Dynamic 2002 with Skyroof, 16" Alloys, in Pitti Blue. No mods........yet
LoBsTeR is offline Reply With Quote Quote
Old 05-06-2008   #7
I've noticed over the last couple of days that it also does it after i have parked up for a while. For instance, it did it yesterday morning, then i drove to work (30 miles) parked up and an hour later had to go out and about, again it juddered on pull off.
I've got it booked into the Fiat garage on Wednesday, but i've already told them it cannot be wear and tear, and if it is then i ain't paying for that with a car with only 25,000 on the clock......
Old 16-06-2008   #8
Sounds exactly the same as my clutch. But my clutch just gave up. So i had it replaced.
I was driving on a juddery clutch for a good 4 weeks. Does it slip at all?
stu_2k1 is offline Reply With Quote Quote
Old 17-06-2008   #9
The clutch doesn't slip, but i haven't made it top the garage yet. Been too busy!
I have since found that if i raise the clutch pedal quicker than what i would normally do then it doesn't judder at all.
I will take it to the garage before my 12 month's warranty is up, the only thing that bothers me is that if they don't find a fault i'll to pay for their labour time.....
Old 17-06-2008   #10
popping out
if they cannot diagnose the fault then they cannot charge you.
Old 18-06-2008   #11
Quote Originally Posted by dan-the-man View Post
Exactly what i said, but they are insistent that they will have to charge me. Haven't taken it yet, on a good/bad note, it just did the juddering in second gear when i changed up from first.
Old 18-06-2008   #12
popping out
FIAT didn't charge me when they couldn't find the fault on mine, they just told me to "go somewhere else" lol so they just lying.
Old 21-06-2008   #13
did you find out what is was as mine does the same?
[B]I want to die peacefully in my sleep. like my Uncle…….not screaming like the passengers in his car.[/B]
Fiat Stilo 1.6 16v Active. 5 door.
swansea2007 is offline Reply With Quote Quote
Old 23-06-2008   #14
its likely to be the clutch.
My 1.2 does it, but only if you drive like your driving miss daisy.
My first gearbox ruined a clutch by pissing oil over it when it exploded.
I have never thought the stilo clutch in the 1.2 to be up to that much really, it gets hot quick and as soon as it is, it slips
2008 Fiat Bravo T-Jet 150 Sport
2014 Fiat 500 S
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline Reply With Quote Quote
Old 23-06-2008   #15
Quote Originally Posted by swansea2007 View Post
I haven't taken it to the garage yet. I want it to be more pronounced so that the morons at the dealer will accept it under the warranty, i'm not paying them for not finding a fault!
(G) Stilo - engine judder and temp gauge volatile 1968hammer Stilo 3 21-05-2008 23:55
(G) Fiat Ducato 1999 1.9d pulling to the left & after turning around pull to the right dodgyfiatvan Ducato 5 16-11-2007 20:10
Fiat unoT vid, and loads of other vids I am pulling up faster4_tec Lets Talk FIAT 8 01-06-2006 16:57
pulling power! in your fiat.. NowIsGone1106 Leisure Lounge 60 04-02-2004 23:04
(T) Judder when pulling away nikeboy66 Punto (Mk2/2b) 8 04-03-2003 06:33
