andrewduerden
- May 11, 2008
- 2
- 1
Now that the weather has finally warmed up I tried to press the "snow flake" button that should chill the air coming out of the blowers. When I do this, the light comes on the button but the air doesn't get any cooler. It was last summer when I last pressed this button and it worked fine then. I want to check the fuse first of all but I dont have the manual to find out which fuse it might be. Does anyone have the manual for the Active Air Con who would be kind enough to look it up for me? I know I could remove each fuse and check if any are blown but I suspect that if I remove the fuse for the stereo it will ask for a code when I next turn it on .... a code I dont have.
Many thanks
Andrew
Many thanks
Andrew
