- Oct 6, 2006
- 16
- 7
Hi all,
Firstly before I get flamed (cos I am sure this has come up before) I have done a forum search and not found much detailed advice....anyway heer is my question....
Firstly my problem with the SAT NAV in my Abarth '52 is that more aften than not I looses connect to the SA NAv antenna IE the sat pic is not green and diagnostics says fault with antenna. However sometime it kicks back in, I get the green SAT icon and all is well...just up unitl it goes off again.
I am thinking loose wire (anyone any other ideas) so my first solution is to remove headunit and check all wires at the back are seated properly, namely the GPS antenna.....only I can't remove the head unit. I have done the cut up coat hanger thing into the two holes on the front but that does not seem to release anything so the unit does not slide out. Scared of applying too much presure pulling out of the cut out hidden by the glove box lid.
Any thought much appreciated.
Again, sorry if solution already posted
Thanks JD
Ps anybody have had the antenna loosing connection issue?
PPs this is a great forun, no really:worship:
Thanks JD
