FIAT Auto Specialist Team
Old 27-02-2008   #1
Morewine (Dave)
Please if you can help I replaced the rear pads and discs on my Stilo 2.4 arbarth as described on the forum but they are now sticking a local garage say I should replace the calipers (ouch) or have I done something wrong. Wound them back using a G clamp and an angle grinder tool but they are very tight? Any advice would be more than welcome petrol consumption is dropping fast
morewine is offline Reply With Quote Quote
Old 27-02-2008   #2
Status: DEFCON Grumpy
custard's Avatar
Trader Rating: 1
custard has donated!
Re: Morewine (Dave)
perhaps the pistons need cleaning & lubing?
Old 27-02-2008   #3
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Re: Morewine (Dave)
Bit surprised you changed the discs
Do they stick using both hand & foot brake?
I presume you're checking them whilst on axle stands?
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 27-02-2008   #4
Re: Morewine (Dave)
Hi thanks for the replies they are sticking with both all the time as if not wound back enough but I cant seem to wind them back any further? Perhaps I can try the cleaning and greasing? I now agree about the disc's but took recommendation from garage
Old 27-02-2008   #5
custard's Avatar
Trader Rating: 1
Re: Morewine (Dave)
it maybe you need to remove the pads and brings the pistons out a bit.
then clean the threads & lube
then see if that allows the piston back in.
if you wound some crap in the 1st time then you may ned to wind them out
a couple of times to clear the crap
Thanks morewine thanked for this post
Old 27-02-2008   #6
Argonought's Avatar
Re: Morewine (Dave)
As I expect you've read many times whilst searching - it really is a lot easier with the proper Fiat Wind Back Tool (only about 15-20 too).
It seems rather odd you've got the identical problem on both sides. Quite honestly, if the rubber seals (around piston) are still good then I can't see lack of lubrication being a problem.
Old 28-02-2008   #7
Re: Morewine (Dave)
Loosen off the handbrake cable adjuster.
john55 is offline Reply With Quote Quote
Old 28-02-2008   #8
Driver Extraordinaire
minimad99 has donated!
Re: Morewine (Dave)
Quote Originally Posted by john55 View Post
Did you loosen the handbrake prior to changing everything? If not that may be you problem.
minimad99 is offline Reply With Quote Quote
Old 28-02-2008   #9
Argonought's Avatar
Re: Morewine (Dave)
It's not critical to adjust the handbrake adjuster although obviously it must be OFF (it auto adjusts once new pads are in place). You should be able to pull up the lever several times before it adjusts properly and I'd recommend doing this before using the foot pedal. This is because the handbrake winds the pistons in whilst the foot pedal just pushes them in
That said, I can't imagine anyone being able to wind the pistons back if the handbrake was even lightly on
Old 28-02-2008   #10
Re: Morewine (Dave)
Thanks again to all. I have tried to order the wind back tool from a Fiat dealer in West Yorkshire only to be told it would not be delivered until mid April
I can't wait that long if anybody knows of an alterative please lt me know also is there a way to reset the service light as I had it serviced at a local garage and they could not manage it
vote dave (my last attempt dave) sammiboo Polling Station 26 16-01-2008 21:09
Aliens from the planet Dave christopher watson Leisure Lounge 0 12-04-2006 00:59
Mrs Dave the one Leisure Lounge 22 02-01-2006 21:15
FAO Dave Liam Auction Watch 2 26-11-2004 10:09
