JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You should upgrade or use an
alternative browser .
General Interior light/Map light assembly removal
X
Just wondering if anyone can tell me how to remove the interior light/map light assembly.
At certain revs, there's an annoying vibration coming from it. Sounds like it's something touching the inside like a loose bulb or wiring connector, that rattles when we hit certain revs.
Cheers.
BJ.
Hello m8 i have one tutorial ready on my had's but i have no idea how to post some photos on..... if you want mail me is [email protected]
9.7 KB
12.1 KB
19 KB
Just for finish i forget the second part sorry
27 KB
I changed the interior bulb in mine the other day...
I recommend a blunt rod like the top end of a pen for squeezing in the tabs on the oddment tray.
You will need quite a large torx screwdriver or equivalent from a socket set to remove the two big screws once the oddment tray has been lifted off.
It was a fiddlier job than it should have been
