General Interior light/Map light assembly removal
Blood Junkie
Just wondering if anyone can tell me how to remove the interior light/map light assembly.
At certain revs, there's an annoying vibration coming from it. Sounds like it's something touching the inside like a loose bulb or wiring connector, that rattles when we hit certain revs.
Cheers.
BJ.:cool:
attachment.php
Just for finish i forget the second part sorry
attachment.php
I changed the interior bulb in mine the other day...
I recommend a blunt rod like the top end of a pen for squeezing in the tabs on the oddment tray.
You will need quite a large torx screwdriver or equivalent from a socket set to remove the two big screws once the oddment tray has been lifted off.
It was a fiddlier job than it should have been ;)
