Technical Charging Battery
hydie331
Hi, the battery on my 2003 1.6 stilo is playing up. It doesn't seem to charge up very well and struggles to turn the engine over on a cold morning. Also when i raise the revs just above idle speed the headlights get brighter in an instant not gradualy. If i disconnect the battery on the car charging can i expect any problems such as lost codes (i know i might loose the radio code, which i dont have) but will anything else go down?
Regards
Hydie331
sounds like a knakered battery. charging it off the car wont help and you may make it explode if you are unlucky. Buy a new battery.
