FIAT Auto Specialist Team
Old 25-01-2008   #1
DIY timing belt (cam belt)
Hi all,
I am thinking to replace the timing belt by myself. I have many mechanic experience... However, I heard there is no TDC mark on FIAT cam sprocket. This might be a bit difficult. Anyone can confirm this?
Another thing is it might need a special tool to lock the cam at the right place. I don't have that special tool.... Is it really required?
Thanks in advance.
shiningliao is offline Reply With Quote Quote
Old 25-01-2008   #2
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Re: DIY timing belt (cam belt)
Stacks of info on this if you use Search but the simple answer is YES & YES
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 25-01-2008   #3
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: DIY timing belt (cam belt)
Yes you need cam lockers ..but if you know your stuff then you will know its always possible to make your own marks .. its very crucial that the belt goes back on perfectly or problems with running can occur ..and cam lockers will guarantee that this happens time and time again..
PNL is offline Reply With Quote Quote
Old 26-01-2008   #4
Quote Originally Posted by Argonought View Post
I have done a bit of search. Some people said there is no mark... but the manual says there is a mark on it.... (see the attached diagram from the manual)
So, I am a bit confused... anyone actually replaced the belt by himself?
Old 26-01-2008   #5
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Fiats don't tend to have timing marks as it's done a much more accurate way
Two camshafts and a crankshaft all to get exactly in line. 40 teeth so one tooth= 9 degrees = way out. 1/2 a tooth= 4.5 degrees = still crap
It may sound complicated but you lock camshafts and crankshaft in exactly the right place mechanically and then, very importantly, you loosen and rotate the camshaft sprockets on the camshafts so the belt fits perfectly in exactly the right place. Then you lock everything back up as only then do you have everything synchronised perfectly. Many garages don't do that as you need the proper camshaft and crankshaft locking tools. The car comes out running like a dog with 3 legs. It has to go back or taken to someone who then does the job properly. Big waste of time.
After 5 years the belt will have stretched quite a bit so it's not good lining it up with the way it is now
It's the one chance to get everything lined back up the way it should be
Mine had a horrid flat spot from when i'd bought it that was instantly cured by lining everything up again with a cam belt change using the correct tools. It's really not very expensive a job to have someone do the job properly with the correct tools as it doesn't take very long
Change the air con belt if you have a separate one like the 1.6 has as it's a stretch fit and it doesn't stretch any more after 5 years use
Thanks shiningliao thanked for this post
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 26-01-2008   #6
Quote Originally Posted by Deckchair5 View Post
Thank you so much for the explanation. I can see it is lots of benefit to use locking tools to lock camshaft and cranshaft so that the timing precision is readjust to the best.
Now, this worries me even if I put my Stilo into the garage. It's difficult to know if they have done the job properly or just the old fashion way which doesn't use any lock tools.
Mine is 1.9 JTD. I found it's same engine as Alfa Romeo 147 JTD. Here is a link to help people to repalce the timing belt by themselves.
http://www.alfaworkshop.co.uk/alfa_jtd_cambelt.shtml
It is clearly that they don't use any lock tools at here....
Old 26-01-2008   #7
Deckchair5's Avatar
Ha! Thought you had a 1.6
Scrub all that. JTD has timing marks
99 Bravo 1.2SX
Old 26-01-2008   #8
I got it! Cheers,
Check the 1.6 manual. It is different from 1.9 JTD. 1.6 requires the camshaft lock tool as shown in the attached diagram.
Old 26-01-2008   #9
mines up for this soon and theres no way i am going to do this.
Is it best to let fiat go at it?
2008 Fiat Bravo T-Jet 150 Sport
2014 Fiat 500 S
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline Reply With Quote Quote
Old 26-01-2008   #10
Deckchair5's Avatar
Yes or a Fiat specialist. The 1.2 needs special cam alignment tools too. Cheapest of the bunch to replace though for parts. I'd recommend changing the water pump and aux drive belt at the same time on the 1.2
99 Bravo 1.2SX
Old 27-01-2008   #11
going to get the aux belt changed anyway, as in all this wet weather we have had, it sounded like a trapped chipmunk was under the bonnet
2014 Fiat 500 S
(T) JTD105 Cambelt Change Timing Belt tension JTDLee Marea 7 11-11-2008 02:27
(T) cam belt jtd 75 stevefog Marea 4 26-10-2007 14:02
(G) 1.2 16V cam belt / timing tools SidewaysMatt Punto (Mk2/2b) 0 12-09-2007 17:11
(T) What on earth happened here!!!!???? Timing belt kritip Cinquecento / Seicento 6 20-05-2007 00:49
