Re: Door check bar
This method works great if you can get the door card off its a t**t, I did my wifes at the weekend and all I did was undone the screws at the bottom of door and removed the bolts securing the card to door & behind door opener, I also popped out the window controller as their is a screw in their also and disconnected it. I then carefully pulled the card away from the door to enable me to get a stubby phillips driver in (Take care you dont pull it to far)and unscrewed the speaker, once this is done you can get your hand in and the door check is a doddle to fit, reverse procedure to complete, voila a door check fittedDone this on the 3dr, as they were modded in 04/05 for a more smooth, solid door close.
eLEARN is bull for this - you don't need to take the glass out, or touch the BC wiring at all.
Easy method:
1. Open the door.
2. Remove the door card.
3. Remove the speaker.
4. With the door half closed, remove the two bolts securing the check-strap to the body.
5. Remove the two bolts keeping it secured to the door.
6. Remove the check strap, removing the seal half way through pulling the strap into the door.
Refit is reverse of remocal.
It really is easy, promise . Took me 30 mins or less per door.
