im Axle Specialists
Old 19-12-2007   #1
Wierd click/clunk on rear wheel [anti-rattle clips?]
Recently, I have been hearing a clicking/clunking noise under braking, regardless whether its light braking or heavey braking. At first I thought, oh poo, my driveshafts had it, as its a very similar noise to that kind of fault.
I got my old man to stand next to the car as I broke and he was determined it was coming from the rear wheel, passenger side. I didnt believe him as in the car it sounds like its coming off of the front end, so i stood outside the car, and he did the same and the clicking/clunking is coming off the rear passenger wheel.
Now, i havent had time to take the wheel off to look behind it as its always dark when im free, but obviously something isnt right. There is also a rattle from the back end when going over bumps, like something is loose, and in the rattle you can hear the noise.
Before I look has anyone got any ideas? I recently had the brake pads on the rear changed by a garage and im wandering if something is loose on the calliper, or that the self adjustment thing is not hooked up and is clicking as its missing adjusting and rattling because its loose. Braking is fine and the drive is fine. Another idea is a busted bush, but the car is not making the noise on the suspension, and the noise doesnt happen on every application of the brake or bump. (and like a i said it doesnt matter if its gentle braking at 40mph or 5mph or slamming on at 40mph or 5mph)
I have had a look under the car with a torch and cant see anything obvious, so the wheel does need to come off
Just wondering if anyone on here has had anything like this, or has an idea as to what it is as forum search hasnt picked anything up for me to go off
2008 Fiat Bravo T-Jet 150 Sport
2014 Fiat 500 S
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline Reply With Quote Quote
Old 19-12-2007   #2
Fiat = Ticking BOMB!
Noclu3's Avatar
Noclu3 has donated!
re: Wierd click/clunk on rear wheel [anti-rattle clips?]
without sounding patronising, are you sure its not the rear subframe?
If my reply has helped you please give me a
(03) Fiat STILO JTD[115 + Red-DotMagic!] Multiwagon Dynamic - 1st ever Fiat (God I hope I made the right choice! )
Please don't complain about my spelling
Noclu3 is offline Reply With Quote Quote
Old 19-12-2007   #3
Sounds like either the caliper/carrier isn't fully tight, or maybe the brake pad anti-rattle clips are missing.
D4nny8oy is offline Reply With Quote Quote
Old 19-12-2007   #4
Quote Originally Posted by Noclu3 View Post
Pretty sure its not this, im more convinced its related to brakes as it was sudden, and thats the most recently touched part in that area, and from trawling through all the posts i dont have any of the other symptoms of subframe bushes
I know the wheel will have to come off to investigate further.
Nothings interfering with the braking, its just this noise isnt right. At least I know its not a drive shaft about to give out
2014 Fiat 500 S
Old 20-12-2007   #5
Dislikeskeyboardwarriors
Steely's Avatar
Steely has donated!
sounds very much like the caliper is loose... only held on to the hub/arm by 2 17mm headed bolts... if these were loose i would imagine a clunking/ kocking noise..... as the caliper is grabbing the disc and shifting
have you tried reversing then breaking then going forward and doing the same.. this would show it
* no anti rattle shims fitted
*loose caliper mounting bolts
*loose caliper cage bolts/splines ( the ones which the caliper slides on)
did they locktite them/ set the torque right???
is it getting worse???
Steely is offline Reply With Quote Quote
Old 22-12-2007   #6
Was going to take the wheel off and have a look today, but lucky ol' me has had a front spring snap on my way home last night.
The noise is still there
2014 Fiat 500 S
Old 31-12-2007   #7
Well had the wheel off and it appears the inner brake pad is loose, and casuing the rattle and click.
Spoke to fiat and it could be either the metal spring clip which is 6.50 or the clips off the brake pad, which means new pads again, after paying 40 3 months to get them changed (pads and fitting)
I will need to take the other wheel off to see what it should look like, and which clip is missing.
Will also get some photos up to
2014 Fiat 500 S
Old 12-01-2008   #8
this is doing it on both sides now, so I cant tell which clip is missing
anyone got an exploded diagram of the rear brake calliper or photo graphs and close ups of the pads in the calliper?
thanks
2014 Fiat 500 S
Old 12-01-2008   #9
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
BBS, that sounds crazy to me
If you've paid to have rear pads fitted and someone didn't fit the spring clips back properly (maybe put them on back to front ) then that's their problem - not yours.
I'd take it back and tell them to sort it
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 12-01-2008   #10
There's no clips on the pads themselves. The anti-rattle clips come supplied with the pads in separate bags (as a kit) and merely push into the caliper-carrier assembly.
It should be clear if any of the clips are missing as they overhang the carrier and have a 'tag' on the outer edge to provide a guide when fitting the pads.
Old 12-01-2008   #11
Argonought's Avatar
Quote Originally Posted by D4nny8oy View Post
I never realized OEM pads are supplied with new anti-rattle clips.
Old 15-01-2008   #12
sounds like this is what is missing from mine then. Is it new pads time again or can i get some seperately or does anyone have any spare knocking about from their rear change?
No point going back to the garage, it was done as a favour and I supplied the part.
2014 Fiat 500 S
Old 23-01-2008   #13
Trader Rating: 1
T.E.D. Jordan has donated!
i'll have a look 2morrow,my dad more than likely has them
Jordan
Total Engineering Developments
T.E.D. Jordan is offline Reply With Quote Quote
Old 23-01-2008   #14
cheers!
2014 Fiat 500 S
Old 25-01-2008   #15
T.E.D. Jordan, did your dad have any?
Btw the way the clicking is getting louder now and clunking more often
2014 Fiat 500 S
(T) Rear Wheel Clunk!!! MareaWeekender Marea 6 24-07-2008 12:46
clunk click every trip jug Leisure Lounge 25 13-08-2007 08:33
(T) Brake caliper anti-rattle clips? tonyfurnell Uno 10 03-03-2007 09:33
(T) Brake pedal clunk/click thomash Punto (Mk2/2b) 4 19-10-2004 08:08
