DeanF
Stilo 1.9 Jtd 2003 115 WIth Angel remap & 74000 Miles.
Potential Items & reasons/thoughts for this.
Error code on my Ecu P0235 Overboost (New overboost valve on order) All Hoses/Pipes have been checked for leaks/splits.
Overboost valve.
Inconsistent operation , Closing & or not closing/operating the actuator & doing this at the incorrect time.
Turbo Actuator.
Sticking open or closed & again not working at the correct time dues to being slow Etc. Damaged diaphram, But i believe this would give a consistent issue.
Inlet Manifold Pressure Sensor.
Faulty & sending the incorrect values to the Ecu which in turn mixes up Boost, Air Fuel Etc.
Mass Air Flow Meter (MAF)
Faulty, Therfore giving incorrect values to the Ecu which again gives the engine the incorrct amount of Fuel , Air & boost.
Turbo.
Worn out/Faulty. Not producing enough boost pressure, Too Much !!
I don't believe this to be the issue as generally from past experience a faulty turbo is either nosiy or lame, Resulting in over fueling lots of Smoke. I believe this fault would also be consistent.
Please feel free to add your thoughts / Components
Dean
Overboost valve.
Turbo Actuator.
Turbo.
Dean
