General windscreen de-mister vent
jayteedee
Hi... just thought i'd ask around to see if anyone has also heard a strange buzzing noise from the above mentioned vent (on the drivers side)?
It only happens when you have the heater on, with the flow coming out of the vent. Basically there's a buzzing noise which keeps perfectly in tune with the engine note! It's definately the vent as i've put my hand on it when driving and the noise stops.
Is there something that needs to be moved/clicked/pushed? I don't fancy taking the dash apart as it's not neccessarilly a huge problem and it's not bothering me too much. However would like to fix it possible.
Thanks in advance.
Mine had a rattle from the front vents once, and it was driving me mad in traffic :mad:
all i did was turn the heaters onto full blast, and out blew a few leaves :D and a receipt ;)
have a good luck with a torch and make sure that there isnt any debris caught down them (y)
One of the clips on the drivers side has broke, and buzzes occasionally
This seems quite common. I used superglue. If you get the one with the little brush, it's a doddle to fix. You will need to poke a finger into the vent to lift it.
