![]() | #1 | ||
Join Date: Apr 2004 Location: stenhousemuir/scotland, United Kingdom.
Posts: 347 Thanks: 0 Trader Rating: 0 | Climate control - how do you use it? my abarth selespeed should be here in a few weeks, and i have been reading my manual in anticipation, but i dont understand the difference beetween aircon and climate control. should you leave the climate control on all the time on auto? how do you work yours. ![]()
![]() | #2 | ||
Posts: 359 Thanks: 0 Trader Rating: 0 | Aircon relies on you manually controlling the hot/cold air mix to get the desired temperature. Climate control is basically the same system, but with some clever electronics on the front end that distribute hot/cold air in the best combination to maintain the temperature(s) you have selected. With climate control you simpy set the temperature and forget about it, on FULL AUTO it does it all for you, including recirculating air when it detects pollution etc (AQS). Don't bother turning off the air conditioning unit when its cold, because it acts as a dehumidifier and is great in winter for preventing misting on the screen. On some cars you notice the power drain on the engine when the compressor is running, on the Abarth it isn't noticeable at all! Once you've had climate control, you'll never want a car without it - enjoy! Paul P.S. If your reading the manual, read the section on the selespeed lots of times - despite what most people think, the Selespeed is very hard to drive properly, and will take a good few months to get used to. Stilo Abarth 3dr, Broom Yellow (Nov '03)
![]() | #3 | ||
Posts: 347 Thanks: 0 Trader Rating: 0 | thanks for that pjp. as for reading the selespeed section, i could go on mastermind with it. cant wait to get my hands on it though. ![]()
![]() | #4 |
![]() | Dual-Zone Climate Control is there any chance of someone explaining to me how this works - i cant make any sense of the book. basically i set the temps either side i.e. 16 degrees, but no matter what setting it always seems to blow hot! if i press auto and it goes to full-auto on 16 degrees the air-con thing lights up but the blower blows downwards ![]() please help me!!! im either boiling hot or bl00dy freezing! ![]()
__________________ Ex 3dr Stilo JTD in black (155bhp) ![]() Ex 3dr Stilo Abarth in Chrome Grey ![]() |
![]() | #5 |
Posts: 23,471 Thanks: 426 Trader Rating: 1 ![]() | Re: Dual-Zone Climate Control Hmmm - you can't be doing it right ![]() My usual procedure is this - set temp in car, say 20 degrees - then press MONO if just me in the car, so passenger and driver side the same temp. I then press AUTO, and let it do its stuff. It may take some time for the blowers to adjust position, until it gets to a steady temperature all round. How long are you waiting for?
__________________ See you next Tuesday ![]() |
![]() | #6 |
![]() | Re: Dual-Zone Climate Control ive given it half hour or more. do i need to press any of the direction arrows or just set the temp then press auto?
![]() | #7 |
Posts: 23,471 Thanks: 426 Trader Rating: 1 ![]() | Re: Dual-Zone Climate Control ![]() ive given it half hour or more. do i need to press any of the direction arrows or just set the temp then press auto? I just set temp and then press auto - works fine, although in the morning the fans can be on full speed, so I turn them down a bit. Never had any problems with it. Ulysse also has 3 zone CC, and that works a treat.
![]() | #8 |
![]() | Re: Dual-Zone Climate Control let me get this right: get in car turn mono knob to set temp (i.e. 20 deg) do same with auto knob for passenger side press in auto button leave until desired temp is reached two more question if screen is frozen will the blowers auto blow to the up position? does the blower position change when auto is set? i.e. up, down and face?
![]() | #9 |
Posts: 836 Thanks: 17 Trader Rating: 0 ![]() | Re: Dual-Zone Climate Control At this time of year, i don't think you'll get any cold air into the cabin, as the minimum temp. is 16C (and that is hotter than the ouside air). The reason the air comes in at the feet, has to do with hot-air being lighter than cool air, so the air will spread from bottom to top (if you blow hot air in at the top, it will take longer to remove the cold air at the bottom - hope that makes sense ![]() In full-auto mode, the only thing you controlis the desired temp. If you press any other buttons (speed of blower, air-direction buttons etc.) it will go away from full-auto to (semi-)auto. It will now control anything you haven't pushed (if you change speed of blower, i still think it decides where the air should go and vice versa). If you tur off the aircon unit (the star symbol) it goes away from full-auto to (semi-)auto, as it still tries to get the right temp. Again that's how i think it works, if i'm wrong in any way, i blame fiat ![]()
__________________ 2015 Mazda CX-3 2.0 120BHP Optimum Aut. |
![]() | #10 |
Posts: 836 Thanks: 17 Trader Rating: 0 ![]() | Re: Dual-Zone Climate Control ![]() I just set temp and then press auto - works fine, although in the morning the fans can be on full speed, so I turn them down a bit. Never had any problems with it. ![]()
![]() | #11 |
![]() | Re: Dual-Zone Climate Control ![]() The reason the air comes in at the feet, has to do with hot-air being lighter than cool air, so the air will spread from bottom to top (if you blow hot air in at the top, it will take longer to remove the cold air at the bottom - hope that makes sense ![]() ![]()
![]() | #12 |
Posts: 836 Thanks: 17 Trader Rating: 0 ![]() | Re: Dual-Zone Climate Control ![]() let me get this right: get in car turn mono knob to set temp (i.e. 20 deg) do same with auto knob for passenger side press in auto button leave until desired temp is reached ![]() two more question if screen is frozen will the blowers auto blow to the up position? ![]() does the blower position change when auto is set? i.e. up, down and face? Man, it's difficult to explain this in writing (especially when english is not your first language). ![]()
![]() | #13 |
Posts: 23,471 Thanks: 426 Trader Rating: 1 ![]() | Re: Dual-Zone Climate Control ![]() get in car turn mono knob to set temp (i.e. 20 deg) do same with auto knob for passenger side press in auto button
![]() | #14 |
![]() | Re: Dual-Zone Climate Control you guys are the best ill try tomorrow on full auto (which should do everything itself i presume). do i need the air-con button on, on full auto mode though?
![]() | #15 |
Posts: 836 Thanks: 17 Trader Rating: 0 ![]() | Re: Dual-Zone Climate Control ![]() you guys are the best ill try tomorrow on full auto (which should do everything itself i presume). do i need the air-con button on, on full auto mode though? so in short: just press auto and watch it switch to full auto. ![]()
![]() | manderley | Marea | 2 | 07-08-2008 10:29 |
![]() | wing1200a | Grande Punto | 3 | 20-05-2008 21:05 |
![]() | bluebravo | Bravo | 2 | 24-03-2008 19:14 |
