General SW Stilo Rear door handle switch operates as rear glass switch
darko123
As it says in title and my switch for rear glass doesn't work. From the remote everything works OK
Wierd!
what happens when you use the switch for the glass?
Sounds like an electrical glitch, maybe shorting somewhere or water in the boot lid?
Does your rear water squirt work?
I think it does, but window switch or pad is dead. I'll try to disconect it from battery and see if it resets. I t must be two way motor that unlocks window when pressing its pad and rear door when catching the handle. I hope it is not infected by bad luck happening to Fiat electronics, as i heard WD40 is the cure fro any bugg
WD40 rulz, it cures AIDS - at least I heard so...
imas na b92 automobili diskusiju o jtd stilu i nacin kako da skines manual na srpskom
sorry guys for writing in greek, found my countryman.
Problem solved.Glass switch which is assembled on the num.plate lights got some moist and @##$#$$%$@#@boom,took the part off, cleaned contacts and thats it
