Hi guys,
I’m installing a new headunit/DVD player into my car (Kenwood DDX7029 with ipod, TV and Bluetooth!) and from doing a bit of research it seems the Stilo is not wired up to ISO standard on the radio wiring, and that it does not have a switch ignition power feed (only constant from the battery). Is this correct?
This means that the radio will be powered up even when the keys are out of the ignition, which could mean I’ll get back to the car with a flat battery!
So, where’s the best place to pick up a switched feed from in the Stilo that is in close proximity to the radio? Behind the streaming column? Heater controls?
Does anyone know how much draw/amps the radio needs for the switched feed. Will any switched circuit do?
Also, I’d like to use the radio when the car is off, with no keys. If I were to use a switched feed, will I be able to do this?
Matt
Matt
