I wanted for some time to write a diy for grounding the engine bay but time is very little with work. ill just give a crash course on it and a link to the greek page with pics for you guys to see. Basically the grounding of the components of the stilo are very poor leading to many problems. One example is the interior lights not having steady lumination. Dont forget the stilo has 4 multiplex engine management computers. Grounding in general of all electric components will help them work better. Many greek stilo owners noticed that changing the grounds even helped smooth out the throttle body and smoother response. Alot of abs, ebd failures dissapeared (changing the battery to a bigger capacity must be done also to eliminate this). In general changing the grounds to a bigger gauge wire will really help.
http://www.stilo-club.gr/vb3/showthread.php?t=2536
Here is the link from the greek site with pics. Dont forget to disconnect your battery. Points to ground are battery to chassis, throttle body, transmission, valve cover,alternator, and engine management computer
Dont forget to cover the new wire ends with heat wrap. If anyone can find the time to write a guide go ahead with the liks of the pics.
