Hi im trying to fit my Facia Adaptor but im struggling to get the metal cage that the standard headunit went into out can sumbody pleeeeease point me in the righ direction.
do you need too? i took out my standard unit, and fitted my fascia adapter, didn't have to take out anything else.
ok i done this literaly a few hours ago to my stilo. you get the blaukpunt double din fascia with the four screws?
rite i found it pretty much impossible to get the old cage out just cause of the plastic thing at the bottom. there is a simpler way, lol
rite its the four lugs that are the problem, the bottom two, straighten them and point them toward the gear stick, the top two is a wee bit different, straighten them and then bend them back above the cage, then you just keep the cage there and screw the fascia infront of it, the fascia sits out an extra 1mm but i didn have another cage to hold my double din stereo so i needed to keep it there, hope this helps
