Old 20-09-2007   #1
Paparrazi
Neil Barker has donated!
Stilo Abarth thermostat
I have the situation with my 3dr Arbarth (48K) where the engine takes longer to warm-up than it used to - gets to normal pretty quickly when at speed, but in the run-in to work in the morning it seems slower.
I'm guessing that it's a stuck thermostat - is changing a thermostat on an Abarth one of those 'difficult' jobs ?
Neil Barker
Techno Grey 3dr Abarth Selespeed now replaced by a 2008 Toyota Avensis TR 2.2TD
Sadly, I am unable to recommend Sunwin Fiat Derby due to my experiences there
Neil Barker is offline Reply With Quote Quote
Old 20-09-2007   #2
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: Stilo Abarth thermostat
Judging by the pic in the link its a complete sealed unit and just a case of unbolting the old one and bolting on the new one ..
http://www.spangerum.com:7080/navi?M...D=30&DRW_NUM=2
Dont forget to drain down the water first tho
PNL is offline Reply With Quote Quote
Old 20-09-2007   #3
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
See if you can test whether your thermostat is opening by starting the engine from cold and then keep your hand on the water hose near the thermostat. If the thermostat is stuck open the hose will very slowly get warm. If the thermostat is working properly there should be a sudden and unmistakeable rush from cold to very hot, too hot to keep your hand on, as the thermostat opens.
Might save you some work and expense
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 06-09-2009   #4
Andymacselespeed has donated!
I knoiw this is an old thread, but I've noticed my Abarth doesn't warm up as I'd expect, if it is stationary it slowly heats up to temp, but when at speed, it sits at about 1/2 way between cold and midpoint.
ANy advice on changing the stat?
Alfa 156 GTA SW 250bhp of Italian goodness!
Andymacselespeed is offline Reply With Quote Quote
Old 06-09-2009   #5
I'm with MR Ford
ROWENA's Avatar
ROWENA has donated!
One bit of advice is to look at the clips holding the pipes on measure them and go get some jubilee clips the same size and replace the old ones, as they are bloody awful to get off and even worse to put back on, this will save you a lot of time mine on my 1.8 took half an hour start to finish.
Karl
Thanks Andymacselespeed thanked for this post
cwazy wabbit
ROWENA is offline Reply With Quote Quote
Old 06-09-2009   #6
PNL
Banned
PNL's Avatar
PNL has donated!
Good advise from Rowena..change them bloomin clips..and top up with fresh coolant
And here is a diag to help you on your way..
Stat is Number 1..
Old 07-09-2009   #7
Anywhere cheaper than shop4parts for the stat?
I didn't even bother asking at FIAT parts!
I do hate those awkward stuffing clips OEMs use!
Andy
Old 07-09-2009   #8
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Quote Originally Posted by Andymacselespeed View Post
10% discount through Forum (although must donate)
Quote Quote:
Why You might save on carriage
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 13-09-2009   #9
As I expected, FIAT want 49.90 and Shop4 parts want 41 selivered to my door.
this is why I don't bother with FIAT if any other source exists.
Old 13-09-2009   #10
Argonought's Avatar
Lightbulb Re: Stilo Abarth thermostat
Yes; but making assumptions is a dodgy game.
I once bought a new battery from what I assumed would be the cheapest source in town. The following day I visited the main dealer (actually within walking distance) and discovered I could have purchased a branded battery, with a longer warranty for less money (this was actually with a Rover dealer rather than Fiat)
As a general rule you're saver with OEM products too.
Old 14-09-2009   #11
I can see the logic, but my local Fiat dealer isn't too great on getting parts ordered correctly, I've ordered bits from them before and often they arrive and aren't the ones I wanted. I've dealt with shop4parts quite a bit over the last few years and they always get the order spot on.
I just don't have faith in Fiat parts dept. that I use at the moment.
(G) How many Stilos activematt Stilo 755 12-11-2007 14:17
