Old 17-09-2007   #1
Stilolos???
chicken_chau_mein's Avatar
chicken_chau_mein has donated!
Boot light and 3rd brake light.
One thing I hate is poor lighting. Does anyone else think the standard 501 bulb is enough to light up the Stilo's boot? I certainly don't! Well I bought some more 501 bulb holders and planned to fit white LEDs in there.
Now heres the problem: Engine off, the LEDs jus flicker very dimly. Engine on, the LEDs power up at full brightness. Does anyone know how what could be done to get around this? Or has anyone "upgraded" their boot lighting?
Another problem, to me anyway. Two "slots" in the 3rd brake light are no longer working. Call me weird but I love symmetry and I desperately want it fixed. I don't want to pull everything apart "just to have a look". Does anyone know if the LEDs in the 3rd brake light are replaceable and if so with what kind, or would I need a whole new unit?
Any info appreciated. Thanks. Joe.
chicken_chau_mein is offline Reply With Quote Quote
Old 17-09-2007   #2
just can't get enough
toad101's Avatar
toad101 has donated!
Re: Boot light and 3rd brake light.
how have you wired the led's
i think you need to buy a complete brake light unit as you do on the punto
toad101 is offline Reply With Quote Quote
Old 17-09-2007   #3
Stilolos???
The LEDs have not been wired in as of yet but I planned to run them off the wiring from the original boot light. I tested it first by plugging an LED 501 in to the original boot light and was disappointed by the outcome...
Old 19-09-2007   #4
toad101's Avatar
the light flicker could be there's not enough power being drained, i changed some 12v house lights to led's (3 bar spots) and they would flicker but when i put in one normal bulb with two led bulbs flicker stopped
Old 19-09-2007   #5
Stilolos???
I don't know how to get around it. I've tried the original boot light with a number of different type of LEDs, single ones, quad ones, High powered one, they all have the same effect. Maybe i'll just wire them all up and will see what happens...
Any advice on the third brake light? Anyone???
Old 20-09-2007   #6
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
There's a diode actually in the wiring to the boot light to limit power drawn in the event of short circuit to reduce risk of fire or flat battery if the light remains on. That's probably what you're experiencing
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 20-09-2007   #7
Stilolos???
Is there any way possible to get around the diode? I'm only going to use LED's to light up the boot so power drain will be minimal anyway.
Old 20-09-2007   #8
Deckchair5's Avatar
You'd have to get into the boot light wiring and remove the diode from the circuit but i can't say whether that's going to be a good idea or whether it will affect anything else. It's there to stop reverse currents getting back up to the body computer and removing it could be an expensive mistake
Use a torch
99 Bravo 1.2SX
Old 20-09-2007   #9
Stilolos???
Doesn't sound too wise! Guess i'll just have to use normal bulbs then. Thanks matey.
Old 20-09-2007   #10
Stilolos???
Quote Originally Posted by Deckchair5 View Post
Use a torch
I was planning to put one of those pushy thing lights, that i could just stick to the underside of the parcel shelf and could turn it on and off with a push! But thats not very classy...
