General Rear Brakes
General Rear Brakes
welshman
How do i adjust rear brakes? Have already changed the pads now need to take slack out of cable.
Is there an adjuster on cable or do i need to move arms on end of brake calipers to take up slack on both side.
Have fitted new brake calipers as other ones were seized up.
With thanks jeff
You should have slackened off the handbrake adjustment (see how to in Stilo Guides- always look in the Stilo Guides first) before you changed the pads. Then you ratchet up the handbrake adjustment afterwards. That's important as it may mess the handbrake self adjustment up now if you didn't
The handbrake adjustment is under the rear seat ash tray. Stilo guides all the way! As Deck says.
Thanks Lads
Never noticed the Guide bit, have now found it.
First time on this forum so am still finding my way around.
Thanks for pointing me in right direction.
Easy when you know now.
Welshman
Jeff(y)
