I have Stilo 2003 1.6 Multiwagon and I have problem with rear brakes
Left side rear brake adjustment adjusts brake so that brake touches the brake disc all the time.
Contact is so light that when you take off the handbrake and try to pull car moves car smoothly and you dont notice anything. All I can notice is that after driving brake becomes very hot.
The brake pads were worn out on left side and I changed them and cleaned all the surfaces and used proper copperpaste etc. Piston rubber is ok and all the brake lines and hoses are ok.
Today I talked with one repair shop and they told me that this is quite normal problem with Stilo. They told that they have in these cases changed whole brake caliper.
Does somebody know is there some other solution to fix this problem?
(brake is made by Bosch)
