Old 23-07-2007   #1
Stilo front passenger suspension(?) noise & Air con noise
Hi Guys,
Brand new to the forum, own a 2004 UK 54 plate 1.6 5dr dynamic with 21k on the clock. Have been reading many posts here over tyhe past few months, but have never had any real reason to post before!
Really hope you guys can help - would really appreciate it!
Great car but a couple of probs that have suddenly appeared - I am hoping the fiat reliability gremlins have not started paying me visits!
Firstly the front passenger side suspension - high pitched squaks when going over even the tiniest of bumps - makes the same sort of noise whether a huge speed-bump or a tiny imperfection in the road surface. Worse sometimes than other, seems to depend in part on temperature. Car rides and drives absolutely fine and the noise doesnt seem to be related to steeriing - doesnt make noise whenI turn steering wheel. Any ideas?
Secondly, when my a/c compressor is running, the car makes a strange whining noise. Occurs in any gear, but especially in 1st - 3rd, around 1800-2200 rpm. When the a/c/ compressor is not running there is no noise at all.
Someone has said it is the a/c/ compressor that needs replacing - b4 I go ahead with this can anyone confirm or give their opinion on whether this sounds likely!
Thanks so much for your help!
boggy12 is offline Reply With Quote Quote
Old 23-07-2007   #2
Re: Stilo front passenger suspension(?) noise & Air con noise
the AC sounds like a busted bearing, like when an alternator bearing goes
2008 Fiat Bravo T-Jet 150 Sport
2014 Fiat 500 S
Fabbrica Italiana Automobili Torino
Big Black Stilo is offline Reply With Quote Quote
Old 23-07-2007   #3
2.4 abarth in front
lee gagg's Avatar
lee gagg has donated!
Mate i got same problem with my stilo arbarth with regards to the suspension squeaking.I have had numerous attempts at curing this good lubrication to most parts of the suspension temporary solves it but if you can i would do what i was advised go to a car spares shop and invest in some waxoyl and give it a good lub everywhere.Had my brother in car he is convinced its the top shocker mount bearings as when you turn steering it gets worse.Also it seems to go off in the wet as though the water lubriacates it somewhat hope you cure it if you do let me know what you found.My next step is maybe changing top mount bearings.If you didn't know already the stilo's suffer with dodgy suspension so be warned.Cheers Lee
The car in front is a stilo 2.4 abarth The car thats left you for dead was a stilo 2.4 abarth
lee gagg is offline Reply With Quote Quote
Old 23-07-2007   #4
PNL
Banned
PNL's Avatar
PNL has donated!
Cool Re: Stilo front passenger suspension(?) noise & Air con noise
Change the top rubber mount and the bearing that should cure it ..if you dont want to go to the bother of doing so then keep it well lubed
PNL is offline Reply With Quote Quote
(T) Stilo "sucking air" sound DaveX Stilo 21 11-04-2014 22:38
(G) Air Box Modification polecat Marea 105 09-07-2011 18:28
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
(G) Noise from Air Vent/Turbo Lou Ulysse 7 07-06-2004 05:27
(G) Air Con buckster Stilo 9 11-08-2003 16:53
