im Axle Specialists
Old 27-04-2007   #1
Adrenaline Junkie
SwissTony's Avatar
SwissTony has donated!
Abarth Fault Codes Help Please!!!
Hi Guys,
My 2002 Stilo Abarth has just developed the fault of occasionally not starting when the key is turned. The engine turns over but the engine does not fire. A couple of times, locking/unlocking the doors seems to clear the fault however last week, the bloody thing just wouldn't start. I called the AA out who plugged it into the fault diagnosis and it came up with the fault codes P0340, P0571 and P1653. The first two cleared but the 3rd one, (P1653) remains although the car started. The car now has refused to start again but after several unlock/lock attempts, the car eventually started. Any Ideas as to what is going on, or is it an expensive trip to FIAT for a diagnosis??
Tony
FIAT Stilo Abarth 2.4 Selespeed in BROOM YELLOW
SwissTony is offline Reply With Quote Quote
Old 27-04-2007   #2
popping out
dan-the-man has donated!
Re: Abarth Fault Codes Help Please!!!
P1653 - power steering output circuit malfunction
P0340 - camshaft position sensor circuit malfunction
P0571 - cruise sontrol/brake switch A circuit malfunction
Don't know if these are any help at all seems a bit strange that they all should come on at the same time though?
dan-the-man is offline Reply With Quote Quote
Old 27-04-2007   #3
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
I think that 1st one is often due to low battery volts or a bad earth connection (which of course is the same thing)
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 30-04-2007   #4
Former FIAT Obsessive
Rich's Avatar
Trader Rating: 1
Rich has donated!
P1653 would not cause the car to not-start (i.e. it would fire up but the screen would display "Electronic Power Steering Fault").
P0571 - One assumes you have Selespeed, and this fault would mean that the car could be jamming the car in gear (as it wouldn't register that your foot is on the brake), hence the engine would not start. I'd replace it anyway, it's a common issue and cheap to sort.
P0340 - this would almost certainly cause the engine not to start, and would also display an "Engine Fault" message. Do you get this?
Last FIAT: 08 Bravo TJet Sport, Maranello Red
Retrofitted: Blue & Me Nav, Chrome Handles
Sister's: 06 Grande Punto 1.4 Dynamic, Crossover Black, Red Badge Conversion
Sister-in-Law's 58 GP 1.4 Eleganza, Azure Blue, Cimate, Parking Sensors
Previously: Mk.1 Punto, 2x Brava, Barchetta FL, 5x Stilo, Nuova Bravo, and more . . .
Rich is offline Reply With Quote Quote
Old 30-04-2007   #5
Adrenaline Junkie
SwissTony's Avatar
Quote Originally Posted by rroope View Post
Had no faults reported on screen at all apart from the bloody parking sensors! Yes it is a selespeed.
Overall from what you say, i'd go for option 2 the brake sensor, how easy is it for a complete novice to sort? The car is in for it's MOT tomorrow, should I get them to tie it in with that?
Thanks for the answers though.
Swiss
Old 01-05-2007   #6
Rich's Avatar
Trader Rating: 1
Rich has donated!
Quote Originally Posted by SwissTony View Post
Swiss
Hey Swiss
It's a possible job - there is a guide in the "Guides" section at the top. If it were me though, I'd get FIAT to do it - big hands!
Old 31-05-2007   #7
Adrenaline Junkie
SwissTony's Avatar
Hi Folks,
Just been out to the car and once again it won't start and comes back with fault code P0340 and U1653, both cleared, still wont start!! Rocked car back and forward in gear, now it starts! How am I gonna cure this problem without a trip to FIAT???
Any help please will be greatly appreciated
SwissTony
Old 31-05-2007   #8
Forum Moderator
T14086's Avatar
T14086 has donated!
renew sensor or sensor circuit
Old 07-07-2007   #9
Camshaft Position Sensor ?
Can anyone tell me where this sensor is and how difficult it is to renew it have been told it is faulty by AA the code P0340 this morning have ordered the part 67 just need to fit it ,is there any links to pictures showing location as all i can see is the blue connector by the fuel rail i have e-learn but cant find it on there ?? Any help would be great
thanks
reveds69 is offline Reply With Quote Quote
Old 07-07-2007   #10
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Camshaft Position Sensor ?
Quote Originally Posted by reveds69 View Post
You mean the disc?
Old 07-07-2007   #11
Yes thats right
Old 07-07-2007   #12
I'm guessing you've got a 1.8?
If so, bad luck, it's behind the one of the cam pulleys (cambelt off job).
Incidently, what's the fault? Is it a non-start with the error along the lines of "signal not valid/ coherance with RPM sensor"? If so this points to slipped cambelt timing.
D4nny8oy is offline Reply With Quote Quote
Old 07-07-2007   #13
No car starts and runs fine the dash just flashes up the orange engine sign and the code read a p0340 ??
Dont know what to do is it behind the inlet or exhaust pulley ???
Old 07-07-2007   #14
It's behind the exhaust pulley, though the belt still has to come off. The wiring runs tightly behind a lug on the water pump housing, I had one where the wiring rubbed through.
Try this for more ideas of things to try-
http://www.obd-codes.com/trouble_cod...alfunction.php
(T) heres one for the techies "engine fault" Shaun86 Stilo 24 03-04-2007 16:28
(T) Air Pressure Sensor, Camshaft change? MadBravaDriver Bravo / Brava 2 19-02-2006 21:58
(T) Missing camshaft sensor! Neo-The Matrix Punto (Mk2/2b) 1 18-04-2005 15:48
