myles0406
Hello,
My first post on here, but I've been a frequent viewer! Hopefully this may be a simple fix!
I understand that these 2 codes relate to problems with the lambda sensor, but i'm unsure whether I should get it checked over by a dealership - £££. The problem began after I had the centre pipe of my exhaust replaced after it failed its MOT.
Apart from the obvious bleeping when starting up, the revs tend to fluctuate a bit when idling.
Could this simply be a case of having to reset the ecu or reconnect a plug somewhere???
