Technical Stilo 1.2 Engine Fault
koe_182
On my way to work this morning just coming off the motorway i got a beep beep noise followed by Engine fault and a Spanner appear on my dash, this then stopped and dissapeared. when it happened the car juddered slightly but carried on going.
its a 1.2 3dr Active 16v.
I have spoken to my most local dealer and they said it may have just been a slight hiccup and that if it comes back on and stays on to make a appointment to go in and get it wired up to their computer.
im really worried they may be fobbing me off, am i gonna do damage by trying to drive again?
any ideas what it could be?
ta (y)
your car is very clever and the light will stay on if it is a very important fault.
The flash means its a "soft" fault, like a slight misfire (needs a service) or a sensor is giving what it thinks a slow/false reading like a lambda probe.
If you notice mpg going down it might be worth wiring it up.
If you are in the london area going to ace cafe pm me and I will bring the equipment for you.
Could probably be a coil on the way out. Very very very very common fault. I have a 1.6 and have had to replace all 4 coils. I presume the 1.2 has similar coils. If i'm right, don't worry about it - dead easy to fix. Less than £50 for the new coil and about 10 minutes to replace it.
There is a stack of info on here about it. Just use the "search" function (y)
Unfortuntaly im way up north, but thanks for the very kind offer.
the local fiat dealership quoted £76 to do a diagnostics?? if it is this coil needs doing its gonna end up costing a bit along with their labour charge.
not good when im skint.
or is it something easy enough to do myself?
thanks for the advice tho, i'll see how it goes on the way home.
does anyone happen to have a guide to replacing aforementioned coils, then i can see if its something i or one of my colleagues could do ourselves?
ive had a quick search and cant find anything
cheers
well its just done it again on the way home from work, rang the garage i bought it off (not a fiat dealer) said to bring it in tomorrow, i hope its not gonna take forever, need to work and back! grrr
