Comment
Guide Tools
HOW TO CHANGE YOUR DROP LINKS (OR ANTI ROLL BAR LINKS) IN 30MINS
Deckchair5
03-03-2007
<font face="Arial"><font size="3">HOW TO CHANGE YOUR DROP LINKS (OR ANTI ROLL BAR LINKS) IN 30MINS</font></font><br />
<br />
<font face="Arial"><font size="3">Well first of all you, do you need to change them? What’s the symptoms?</font></font><br />
<font face="Arial"><font size="3">A kind of
Old 30-04-2014   #30
itsowenhowarth has donated!
Re: HOW TO CHANGE YOUR DROP LINKS (OR ANTI ROLL BAR LINKS) IN 30MINS
After reading this i gained the confidence to try this myself and save some money on labor costs!
I took the wheel off and found it to be easier than the guide suggested, i didnt have any hex nuts or anything.
Used a 14 spanner on the back to stop the ball joint spinning and used a 17 rather spanner on the front... after some very small very difficult turns i got both bolts off!!
Popped the link bar out.
Trying to get the new ones in wasnt easy! I had to clamp the anti roll bar to the wishbone to pull it down so i could slot them in!
Good sense of self accomplishment... hungry for more tasks!!
This forum is so valuable!!
Thanks wody21 thanked for this post
Likes Most Easterly Pandas liked this post
itsowenhowarth is offline Reply With Quote Quote
Old 30-04-2014   #31
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Quote Originally Posted by itsowenhowarth View Post
Could always donate some of that saved money to the running of the forum
https://www.fiatforum.com/donations.php
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 30-04-2014   #32
Gonna do it when I get in.
Old 05-07-2014   #33
sussexa has donated!
going to be doing these soon, thought id post some pics of these heavy duty meyle drop links.
look considerably more man than the std ones on car now.
didn't seem muchmore expensive at £26.50 for a pair considering the quality and 4 yr warranty, plus plenty of posts of cheap ones failing fast.
sussexa is offline Reply With Quote Quote
Old 06-07-2014   #34
all done , as others found top nut off easy bottom one not cut my losses and used dremel and cutting wheel to cut slot through nut then mole grips on the rubber boot held it enough to spin off the nut.
the meyle ones came with new nuts requiring 15mm spanner and also a thinned down 16mm spanner to hold the boot side.
I was supprised how much spring was in the anti roll bar, a big bar levering through the hole in the lower arm was enough.
Old 09-07-2014   #35
I just replaced with Meyle HD a couple of days ago too and can confirm that side to side with the oe fiat ones they seem much beefier, also the system for securing should be easier in the future should it ever need doing.
As everyone else said bottom nut was on so hard, my brother who was helping me snapped a spanner, he gave up after that so i got a better quality spanner and the fiat jack and did it up by hand (the jack) until it turned, and it worked! doubt its safe to jack against a spanner though so proceed with caution
daveofkent is offline Reply With Quote Quote
Old 16-10-2015   #36
Will be changing mine tomorrow.
Earlier in the week heard a clunk, then a rattling noise.
Had a look underneath and found the n/s droplink had completely broken.
The top is still secured, but the bottom, the ball joint had come apart away from the bolt, and was just flopping around....no wonder it felt different going round corners
Cinq999 is offline Reply With Quote Quote
Old 18-04-2019   #37
Ireland
This guy can do it in 4 minutes...
General Disarray is offline Reply With Quote Quote
Comment
Guide Tools
(T) Marea 1.8 HLX Anti Roll Bar ksimpson Marea 41 03-02-2009 14:44
(G) Anti Bar Roll Link for Fiat Marea javednazeer Marea 2 13-11-2005 15:53
(T) Cing Sporting Anti Roll Bar - on SX?? arseofbox Cinquecento / Seicento 9 13-03-2004 01:35
(G) sei anti roll bar Blue Seid Boy Cinquecento / Seicento 5 07-08-2003 05:47
