Amp wire - How I Did It
First - Find the gromet - Its located on the passager side just under the windscreen, about 3 inches from the edge of the inner wing - In the pic below you can not see the gromet but you can see the black silicon used to cover the hole the cable went through - I could only poke the gromet out so I made sure no water could get in to the car by filling with black silicon, its in a very dry place but its good not to take chances.
Below is a wider pic - follow the red wire
  • Thanks
Reactions: JayEm
