Comment
Guide Tools
Installing an after market stereo
Stuart_89
03-09-2008
Fist off you will need an old wire coat hanger. Using some wire cutters cut out four straight pieces about 8cm's long. They need to be long enough to be pushed through the four small holes on the standard stereo.<br />
<br />
<div align="center"
Old 04-07-2014   #45
Re: Installing an after market stereo
all sorted now doing it mooncheese way didnt work for me..the unit came on but i could not turn it of..so i swapped both the red wire and yellow bullets round and the ..and it all works perfect
webby99 is offline Reply With Quote Quote
Old 18-07-2014   #46
Netherlands
You can always take the 'ignition controlled' wired off of your cigarette lighter. A was searching under the hood but there doesn't seem to be an switched wire anywhere other than the cigarette lighter inside.
Here's a double-din version I've built in my car. It's a JVC AV-61BT.
drdRiz is offline Reply With Quote Quote
Old 15-12-2014   #47
I took out my standard Fiat radio / cassette player plus the metal cage and installed the new facia . . . all fine up to this point. The aftermarket stereo appears to have no live feed to it . . . its as dead as a door nail. The Fiat stereo worked fine and the aftermarket stereo worked ok until I installed it in my 2004 Stilo.
I did notice on my previous Stilo, where the aftermarket stereo originated from, that one of the thin wires leading into the back of the stereo had been cut and paired with another. Does this make sense to anyone?
Any suggestions would be helpful. . . . . Kevin
kevinstones is offline Reply With Quote Quote
Old 20-01-2015   #48
Hi
Can any one post a link to the correct model of ISO connector to get from halfords. am a bit confused about which one i should be looking for.
dabster1138 is offline Reply With Quote Quote
Old 4 Weeks Ago   #49
But using option 2 only allows to listen to radio with the key in?
abra25 is offline Reply With Quote Quote
Comment
Guide Tools
(S) after market doz smith Bravo 8 14-12-2007 05:09
(T) Fitting after market stereo. Shminkypinky Stilo 7 25-02-2007 10:12
A/market stereo S/wheel controls johnson550 I.C.E 7 05-09-2006 09:05
(T) Starting engine whilst stereo playing disables stereo superleccy Stilo 5 19-09-2004 14:41
