Comment
Guide Tools
Dealing with the 'Preheat Fault' message [Stilo JTD]
Argonought
22-06-2008
Glow plugs (or heater plugs) are used to warm the cylinder on cold mornings when starting a diesel. Unlike spark plugs, which are used continuously in an engine and therefore wear out over time, a glow plug is more like a light bulb and they either work perfectly or they donít work at all.<br />
Old 12-06-2013   #30
Re: Dealing with the 'Preheat Fault' message [Stilo JTD]
I have diagnosed the BLACK wire as the faulty plug - number 3 cylinder. Any hints on gaining access? I tried but it seems impossible on a Stilo 04 Does the EGR valve come off to get in there?
any suggestions would be good.
clarkytwo is offline Reply With Quote Quote
Old 08-11-2013   #31
Malaysia
hi, its more than 1 week my doesn't start. I have check code and got more than 3 error. After keep reading around the net, most of error gone mostly connector. The last error was P0380 glow plug low. Check it and only No 3 got reading = 345??. No. 1 & 2 = 0000 and no 4 = O.L, I will check again today if relay is working.
For info, my car start worst when the starter loose after crank 1 or 2 time.. i think another issue here.
anyway very good OP here, very thanks..
yj09 is offline Reply With Quote Quote
Old 08-12-2013   #32
Hi, very helpful thread, had mine done about a week ago, used it a lot but STILL have light and message flash? Any ideas? Shall I disconnect the battery? Will it "forget" the fault?
chris
Chris127 is offline Reply With Quote Quote
Old 11-01-2014   #33
Just stopped flashing! Thought they would be ok as car starts in cold temp no drama every morning.
Old 16-02-2014   #34
Great Guide! I've added some photos on the setup of the Grande Punto 1.9 MJet for those that might come across this guide for the Stilo and wonder if it's the same in GP:
https://www.fiatforum.com/grande-pun...ml#post3417017
REJOINED is offline Reply With Quote Quote
Old 25-06-2014   #35
Good guide thanks. I made mine pin 4 on the relay plug BUT the red wire is on top of the glow plug/cylinder 4 closest to the battery in the bay.
I suppose that means it could be either Cylinder 4 if I follow my head/wire colour or cylinder 1 if I follow the original post.
It's in at fiat now so I will know soon.
Vegasphil is offline Reply With Quote Quote
Old 25-06-2014   #36
To finish off this post, my red wire on my Punto did go to Cylinder 4 nearest the battery, rather than cyl 1 in the OP.
I Suggest following the wires to confirm where it goes before telling the dealer which one to replace.
Old 15-11-2014   #37
all of my glowplugs are reading 0.7,0.8 is this why my car wont start
1990dtl is offline Reply With Quote Quote
Old 31-05-2016   #38
I'm hopeless with electrickery...
How does this test the glow-plug..?
It looks like the metre is connecting the glowplug (via the wire to the connector block) directly to earth (the engine block). Shouldn't it be in-line with some current or something?
i.e. What electrical circuit is there between the connector block (which is connected to the glow-plug but not to a live/battery) and earth? I'm confused..
Ralf S.
No bullets for chaingun
Ralf S. is offline Reply With Quote Quote
Old 22-10-2016   #39
Quote Originally Posted by Argonought View Post
I don't think a single member has managed to change one successfully yet - other than Fiat Techs of course
Be warned that someone did have a go but ended up with their car being off the road for a while (damaged the injection pipework)
Having the correct tools is critical.
Easy job with loads of 1/4" drive sockets and extensions. No need to remove any fuel lines and so on. It "only" took me 1 hour to do 4 of them. Next time I do it I will make pictures.
gregorymay1984 is offline Reply With Quote Quote
Old 11-11-2017   #40
Hi
I'm going to put some images on here and a breakdown of how it's done. It only took twenty mins for the 4. A coat hanger and rubber hose are useful to lift the plugs in and out but they're more accessible than people think.
Crosby is offline Reply With Quote Quote
Old 11-11-2017   #41
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quote Originally Posted by Crosby View Post
Hi
A breakdown of how to replace the glow plugs, with images, is already in post 7 above.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Comment
Guide Tools
(T) Preheat Fault Warning Jiminspain Stilo 24 13-11-2011 16:51
(T) Engine fault/sensor fault JTD bozzy Stilo 44 20-04-2009 17:59
(T) Pre Heat Fault Stilo jtd...Can anyone Help? Tys_Stilo Stilo 23 28-06-2008 22:49
(T) Preheat Fault on JTD Multiwagon NobleSX Stilo 1 20-12-2007 10:14
(T) Beep, beep, beep!! Preheat Fault! D-Stilo Stilo 27 23-10-2006 21:08
