Comment
Guide Tools
<!-- google_ad_section_start -->Brake light problems-changing the switch<!-- google_ad_section_end -->
Published by Deckchair5
03-04-2007
Difficulty Level: 1
User Rated:
Difficulty Level: 1
Testing the switch
Once the switch is out you can check the operation with a multimeter if you feel the need
REFITTING
Refitting is absolutely nothing like removal (just like it should truthfully say in the Haynes manuals) as you will be all out of patience and fed up with being upside down by then
Thanks Stilo36, avcihuan, JayEm, vladof, Jevge and 4 others thanked for this post
Contents
<<  <    Next Page: Why won't it go in? (Page 2 of 5)    >  >>
Old 28-05-2007   #1
Re: Brake light problems-changing the switch
Hey Deckchair, been a long time. Anyway, once again I have been saved money,time,being stopped by the police thanks to your know how. The brake lights on The DarkStilo were on all the time. Removed brake switch but instead of replacing, pulled plunger all the way out and refitted. Hey Presto!
Red lights only, no blues and twos for me!
darkstilo is offline Reply With Quote Quote
Old 12-06-2008   #2
at my wits end, have had 2 new switches and been back to dealer 7 times with brake lights stuck on! all they say is it needs ajusting , lasts 2mths then stuck on again? 02 3 door stilo, any ideas sugg.estions welcome
paddycov is offline Reply With Quote Quote
Old 20-07-2008   #3
A million thanks for this guide. Just had to reset mine. Might be worth saying that to reset the switch I had to pull quite hard with pliers until the plunger 'clicked' out to its position.
Already paid 70 quid for a rip off merchant mechanic to fix this once..... I shall be having strong words on monday morning!
mylovehatestilostory is offline Reply With Quote Quote
Old 02-09-2008   #4
windtunnel has donated!
Hi, Thanks for the brilliant guide,dosn't help if you have fingers like salami!!!
windtunnel is offline Reply With Quote Quote
Old 13-10-2008   #5
Checkers Champion, GemStack Champion
brilliant guide. wish i'd read this before doing mine - would have saved a few layers of thum skin before filing the locating lugs! ouch!!! just gonna adjust it now..
wheilybin is offline Reply With Quote Quote
Old 18-09-2009   #6
brocherboy has donated!
hi,i replaced mine before finding this ,,and had to lye on my back with my legs in the air over the back of the seat!!! with a torch in my mouth!! took me ten tries with hand ripped to bits i could not get new switch locked in and found i had to trim lugs as they were 2mm 2 long so switch could not fully seat in holes ,
Has anyone noticed there are 2 switch holes and 2 sets of wires/connectors and does anyone no why
And before i did find the switch i was told by fiat to find switch on passenger side ??
brocherboy is offline Reply With Quote Quote
Old 23-10-2009   #7
Andymacselespeed has donated!
I've done this operation recently, the switch now costs 20 from FIAT, and I found that having huge fingers didn't help matters, I found that using a plumbers basin wrench (as used for unbolting tap nuts) works very well. The switch has flat sides and it fits perfectly. The switch on my car was a nightmare to remove. It came out in tiny bits!
Alfa 156 GTA SW 250bhp of Italian goodness!
Andymacselespeed is offline Reply With Quote Quote
Old 16-02-2010   #8
Smile Re: Brake light problems-changing the switch
brilliant, havent changed it yet but at least I can now reset the switch on my brand new multipla (oct 09) and hopefully people will stop coming up to me in car parks and telling me my lights are on all the time - I'll keep a pair of pliers in the car so I can do it as soon as I notice. what a stupid design!!
andrewdouse is offline Reply With Quote Quote
Old 08-04-2010   #9
Romania
i just got that switch. 10 euro's in Romania but the thing is that the problem was from the left back stop lamp. someone changed the bulb and mounted a 10w bulb. the original is 5w. changed the bulb and no bulb failure eror now
mihaitza83 is offline Reply With Quote Quote
Old 20-05-2010   #10
davestilo has donated!
high guys, after reading this about brake lights being on all the time perhaps you can help me,mine dont come on at all,checked bulbs (o.k) checked fuse for bulbs (o.k) and checked fuse for signal from brake (o.k)
The only warning that comes up on the dash is rear r indicator but thats working fine. could this be a brake switch problem?
davestilo is offline Reply With Quote Quote
Old 13-07-2010   #11
thanks this helped me so much sorted my prob
pepper is offline Reply With Quote Quote
Old 02-12-2010   #12
Ex-Schumey proud owner
BLKC99's Avatar
Trader Rating: 1
BLKC99 has donated!
Talking Re: Brake light problems-changing the switch
Just what I was looking for , now I know how, why and when it happened, it was all my fault for my lights being jammed on at all times now, its called careless rushing around in and out of car...........
BLKC99 is offline Reply With Quote Quote
Old 05-12-2010   #13
Where exactly is the switch ? ive had my hand by the brake pedal arm but couldnt find anything? is it in front or behind the arm?? Thanks in advance !!!
sharpy7 is offline Reply With Quote Quote
Old 08-12-2010   #14
BLKC99's Avatar
Trader Rating: 1
BLKC99 has donated!
Here are the pics, i bled for these lollol
ID:	84568   Click image for larger version
ID:	84570   Click image for larger version
ID:	84572   Click image for larger version
Thanks wody21, stilopete, avcihuan, MR GOOSE 1, Stormwatch thanked for this post
Likes pagey61, stilopete, avcihuan liked this post
Comment
Guide Tools
(T) Brake light problem bonzo Doblo 8 24-11-2006 17:23
(G) Attaching a spoiler.. and 3rd brake light Q's arc Cinquecento / Seicento 1 18-06-2005 12:25
(G) Extra brake light donaldmaclennan Ulysse 0 11-06-2005 22:22
(G) Brake light problem - help! Surrey Sporting Panda (Classic) 8 01-07-2003 02:23
