Technical 1242 auto engine - will it fit my Cing box ?
Membury, Devon
I've found a cheap 1242 auto engine which I'd like to fit into my Cinq .Does anyone know if this will this accept my flywheel/clutch & bolt up to my manual box OK ?
John
Bushboy said:
the box all fits on fine but you will need to put the cinq flywheel and clutch on. you will also need to put on the selecta alternator and crank pulley as the cinq ones done line up.. . apart from that. its exactly like using the punto 60 manual engine.
no you got short memory :D cinq flywheel dont fit rember i brought that 1 off a 1.2 manual punto with me?
be VERY careful here - the crank angle sensor may not line up...
Hi Dave
Any more where that one came from?
Adrian
P.s i can`t find any details on crank angle sensor in the haynes manual,which one should i use 1108/1242 and where does it mount?
