FIAT Auto Specialist Team
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Sedici 1.9 TD - How to Fix for lack of power problems from the turbo controller<!-- google_ad_section_end -->
Published by italiAlex
12-07-2018
Difficulty Level: 3
User Rated:Unrated
When it comes to lack of power and stalling, people can often get fixated about EGR's ...
My experience has been that the EGR is a necessary and functioning device that can be quite easily cleaned. There are guides that go into details. Also technical explanations on how they work and how they save fuel too ...
Not long after buying my 2008 Sedici it developed intermittent power problems. It first showed up with the engine dying when pulling up at junctions. There can be several causes for this problem of course.
I finally diagnosed the Turbo Controller, which is located at the top front left and is a moving part that wears out. You can use grips on the vacuum pipes to eliminate its action. It's a bit hidden, behind a squarish panel and underneath where the power steering pipes run across the top, to the left of the dip-stick and to the left of where the air feed drops down to the turbo. You have to unbolt a few clamps and mounts to get the panel out.
The controller might look like a sealed plastic lump with some wires and tubes attached but inside is a constantly moving piston that adjusts the vacuum pull on the the turbo actuator.
Now, these controllers are not cheap and it does take a big leap of faith to replace them. So, before you go doing this I would check the vacuum pipes carefully.
About three years after fixing the controller a new but related fault appeared. Every time the AirCon was on the engine lacked power and was very flat at pull away. There is a design fault that can cause one of the vacuum pipes to split.
I don't know how many of these vehicles had this problem. At some point, I think there was a bigger flexible tube running down to the actuator but the suppliers must have changed the spec. The joining block is a purposefully made item, so my thoughts are that they failed to update this bit when the tube spec changed.
At least, I would like to think that. I can't say that I have been over-whelmed by the build quality of these basically Hungarian built Suzuki's. They seem to be generally good value for the money and people tell me that lots of cars are built like it these days but that is another discussion ...
So, if you have have blowlamp and can solder, what you have to do is cut the flange end off of the offending item, to get a good capillary fit, and solder in reduction to OD 4.5 or 5mm.
I also had to cut the joining matrix into two, to get extra movement to compensate for the reduced available length.
(would like to post photos, but need 5 posts first ..)
Old 26-12-2019   #1
Italy
Re: Sedici 1.9 TD - How to Fix for lack of power problems from the turbo controller
Update:
There is a basic actuator on/off function in the MultiEcuScan software which I discovered recently and may help people.
My general recollections are that mine was working. It just wasn't working properly. At least I think that was the case.
The diagnosis via clamping the vacuum tube isn't the easiest or clearest of things to make, which is why I gave three stars for difficulty. Whether, if the solenoid is on/off not working, the vacuum pressures can passively bypass the control is not something I can comment on.
Also of note, I have changed my mind about modding the EGR system. It is definitely worth doing and not expensive. Fixing the turbo controller solved a lot of performance issues for me but never entirely.
If you think your controller may be playing up but you are in doubt, try MultiEcuScan, do an EGR mod if you haven't yet, and check those vacuum tubes carefully.
italiAlex is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Turbo lag or just lack off power? timfuller1886 Grande Punto 4 05-08-2013 07:34
(T) Lack of power between 1500rpm and 3000rpm. turbo fail? Dave Hall Grande Punto 1 25-02-2012 11:31
(B) Power controller Ahmad 500 0 29-07-2011 18:58
(T) 1999 non turbo scudo lack of/loss of power daz7505 Scudo 2 13-05-2011 07:21
(T) TD - Lack of power, v noisy, little turbo jonti Tipo (Classic) 7 14-01-2007 13:44
