Old 18-06-2021   #1
Fiat 500 SatNav - GPS not working
Hi all.
My daughter has just bought her first (ideal) car, a 2012 Fiat 500 Twinair.
We have an issue with the satnav in that the GPS does work. The satnav thinks that the car is in Newcastle when in fact it is in Gloucestershire.
The SatNav is the Magneti Marelli version, which I know is not ideal but it would be nice to get working properly.
There's an option in the satnav setup which enables/disables the GPS but that makes no difference. I've removed and then reconnected/paired with BlueAndMe2 successfully but that makes no difference.
So I assume that there could be a connection issue with the antenna. Does anyone have any other suggestions or how I can check the antenna conection?
Vic
Vic207 is offline Reply With Quote Quote
Old 22-06-2021   #2
Abarth 500
RedAbarthMTA has donated!
Re: Fiat 500 SatNav - GPS not working
Press on the map to get to main menu, press arrow to move to page 3 of 3, press Status & Information , press GPS Status. This will give you the status screen which tells you how many satellites etc.You may just find you are in a bad area, aerial is internal to the Tomtom unit.
RedAbarthMTA is offline Reply With Quote Quote
Old 23-06-2021   #3
Thanks for your reply RedAbarthMTA. Unfortunately this is a Magneti Marelli not a TomTom devide so the menu options are different and I can't see a GPS status page.
The third page of the Menu shows an Info About button, but pressing this only gives the page showing Pocket Driver 2.8.12.
Attachment 218566
Attachment 218567
I've pressed the Enable/Disable GPS button but there is no difference. I've also pressed reset on the back of the unit and it still thinks I on Newcastle.
Vic
ID:	218568   Click image for larger version
Name:	Info About.jpg
(T) Fiat 500 SatNav dock/port sarah20 500 7 27-07-2020 09:02
Blue&Me SatNav fiat 500 - other models?? Fiat500 Coco Blue and Me 15 30-06-2013 15:50
The GPS of my fiat stilo stopped working gusto84 Satellite Navigation 6 02-10-2012 12:24
(T) Stilo 2003 Satnav Gps martin123 Stilo 2 05-07-2008 11:03
GPS/Satnav for dummies vtec Satellite Navigation 7 09-03-2007 15:14
