uConnect 2019 MAP update
iSquithy
Disclaimer: I can not be held responsible for any damages to your uConnect, Car or your hair falling out from running this modification.
***This is a unofficial Modification to your uConnect - Do not update your unit after applying this modification***
That being said, if you do have a problem please contact me and I will see if I can help you fix it.
For all those people still on v17.07.46 (Fiat and Jeep) v17.07.55 (Alfa) or older uConnect 6.5 firmware I offer you an update your maps. I have to warn you though, the process can take a lot of time!
My current Map pack 2019v1 is based on 2018Q3 maps, these maps have everything working (Speedcam, full postcode search, TMC). I can provide newer map files (2019Q1) however the Speedcam and full 7-digit Postcode search don't work on them currently.
For those of you who have updated your uConnect to v17.35.41 or v18, I am still working on how to update those, FCA / Fiat / Alfa changed the locks with that update!
For a Full EU update, if you follow my instructions fully, it will take approx. 4hours during which time your uConnect must remain powered on. This time can be greatly reduced by only updating the country or countries you need, or if you are feeling brave, skipping Step 1.
Files / Items needed:
uConnect 6.5 running v17.07.xx or older firmware, If your firmware is older that v16, I would strongly recommend updating to v17.07.46 before running my map update.
At least 8gb USB Drive ***preferably with a flashing led light so you can see file access, I use SanDisk Fit USB3 with perfect success***
Files from
https://mega.nz/#F!kURhTCbJ!uJhKPMyGiESbvQSDb33CvQ
Stage 1 – Backup your files
Prep:
Download:
1 Magic -Fiat & Jeep pre UPD.zip -For Fiat / Jeep
2 Backup.zip
Process
1. Download and expand “1 Magic.zip” and “2 Backup.zip”
2. Copy the content onto the root of the USB drive
3. Start car and let uConnect boot up (wait approx 5min for full boot up)
4. Plug in and WAIT, the uConnect will not appear to be doing anything but if you are using a USB with a light you should be able to see it flashing with file activity
5. After some time, in my case it took 1h25 to complete this stage, it should popup a window about there is a update that you MUST answer NO to
6. Pull USB, and power cycle the uConnect*
After that you now have a backup of all the system and map files we are going to change on your uConnect.
KEEP THEM SAFE!
Either use a second USB for stage 2, save the backup folder to your computer or if your like me and use a 16gb USB stick you can leave it where it is.
I have now uploaded copies of the official EU Map Packs from (A) 2013, 2015 and 2017 that should function as a backup or official upgrade for anybody needing to restore or keep official software / maps only.
Stage 2 – Modify your uConnect
Prep:
Download:
1 Magic.zip --You should already have this if you completed Stage 1
D FEU Custom 2019v1.zip --FullEU (Newest update!) - If you just want to update the UK then just download the UK map pack
Or
A EU 2013 Original NQEU2012Q4.zip --Stock 2013 Maps, Original EU Release
A EU Update 2015 HMEU2014Q2.zip --Going back to stock with 2015 Maps
A EU Update 2017 HMEU2015Q4.zip --Newest Original Map files that I have, released 2017
Process
1. Download and expand “1 Magic.zip” and “D XX Custom 2019v1….zip”
2. Copy the content onto the root of the USB drive, if the same stick that contains the back up files, let it replace the Script.lua file
3. Start car and let uConnect boot up (wait approx. 5min for full boot up)
5. After some time, depending on “D” file used - If country only pack approx. 15min if full EU then approx. 2h, it should popup a window about there is a update that you MUST answer NO to
If all gone well you will now have a uConnect 6.5 with updated maps!
**Sometimes with a FEU update, it does not work the first time, to save you having to run the full update again I have created a Fix file that is only needed if your Navigation will not activate after the power cycle.**
*To Power cycle:
Press and hold the Power and Browser / Enter buttons for approx 30 seconds
Or use engineers menu to reset the uConnect (Press Radio, More and Browse until menu pops up, scroll down to Reset Radio, answer YES *****DONT SELECT FACTORY RESTORE****)
I tried do download 2020v1 FEU Custom.zip from mega using different browsers and different computers with different OS (MacOS, Windows, Linux). I always get a corrupt file that cannot be unzipped. The same applies to 2019V2 FEU Custom.zip.
Is there an alternative to Mega to downloads these files?
Hi iSquithy,
Just found this post. I am downloading the files for USA and CA.
Have uconnect 6.5 ver 15.XX.XX. Would this version work?
Hello,
I have Uconnect 6.5 running v15.43. I tried the latest Canada/USA maps following the above steps and now when I try to load up navigation, the message "Navigation is activating" shows up and stays even after 10 minutes. I will try and restore my original 2012 maps and just order the latest ones from Chrysler's website. It is quite expensive after exchange rate and $30 to ship a USB to Canada but at least it will work. Hoping others don't try this and mess up their NAV.
MC
hi have a question for Georgia tbilisi caucasus is there maps where i can found update etc ?
