Old 4 Days Ago   #1
fiat strada abart 130 engine timing
hi can anyone clarify the timing procedure for the 130tc engine....
I know the two camshafts are timed on the marks on the rocker covers, but what about the crankshaft tdc and auxillary shaft position....thks.
fiatsforever is offline Reply With Quote Quote
Old 4 Days Ago   #2
s130 has donated!
Re: fiat strada abart 130 engine timing
Auxillary shaft timing notch should be 34 degrees to the right (clock wise) of vertical. The notch will then be approximately alighed with the right hand edge of the bolt that the tensioner pivots on (if I remember correctly.
The tdc/timing marks for the crank pulley are on the yellow timing belt cover. However if you look at the top of the gearbox bell housing you will find a rectangular rubber blanking plug. Remove this and you will see timing notches on the edge bell housing window apperature. They should be mark 0 - 5 - 10. You will find a corresponding notch on the edge face of the flywheel. Using the bell house marks is far more accurate then crank pulley ones due to the very much larger radius.
s130 is offline Reply With Quote Quote
Old 4 Days Ago   #3
ok thks, will see if I can time it up and see if it runs..
(T) fiat strada abarth 130 electrical problems fiatsforever Ritmo / Strada 4 1 Week Ago 10:40
Fiat Strada 130 tc wheels Mr Brown Auction Watch 5 08-03-2005 16:39
Fiat Strada Abarth 130 TC RACE CAR dave Auction Watch 6 19-04-2004 21:51
Fiat Strada Abarth 130 TC RACE CAR MrDerv Auction Watch 0 17-04-2004 19:44
