hkofoed
Member
- Jun 19, 2017
- 18
- 83
Hi guys - just checking-in as to the best way to remove the 3x 130tc heater cables from the interior side (the old ones have frozen up)
- I have disconnected the engine-side cables from the heat / direction / fresh air connections on the heater-box in the engine bay.
- My question is, do you just remove the front panel and yank the whole unit out, or do you need to "go underneath" and remove via the under-stereo area?
I cant see if the end-cable "kink" right by the panel is the only thing holding the cable, or if there is a white-plastic screw-connector a/p the heater-box end in the engine bay.
Any general advice on how to remove without wrecking the rest of the dash would be appreciated ! My hands are laden with cuts/scuffs so far and im at wits end!
Also - has anyone found a source for the old "fibre optic" panel lights, ie the bulbs with the magnified flat ends. I have replaced mine with a standard lamp and the switches are barely visible at night (ie the rear demist and other switches)
Hamish
Hamish
