Thread Tools
Old 06-07-2018   #1
Sweden
Abarth rear spoiler fitment
I've just bought a good used rear spoiler which came with screws for the five holes with locating dowels but there are also another six holes which look like they take screws,are these extra holes also used as well? Cheers.
Name:	ritmo rear spoiler.jpg
stevieg32 is offline Reply With Quote Quote
Old 07-07-2018   #2
s130 has donated!
Re: Abarth rear spoiler fitment
There are only 5 mountings. Other holes are part of the manufacturing/moulding process. (soft rubber over a firmer carrier block.
FYI: (P/Ns)
5944716 = Spoiler
15644401 = Bolt/Screw (x5)
4458626 = Spacer/Bush (x5)
12638105 = Washer (x5)
Likes stevieg32 liked this post
s130 is offline Reply With Quote Quote
Old 07-07-2018   #3
Sweden
Cheers for that,luckily it came with all the necessary screws and washers so only a matter of some careful measuring and drilling.
Old 07-07-2018   #4
s130 has donated!
Wish you well with the drilling.
I would advise that Strada tailgates are well known for corrosion. All starts at the window rubber lower corners. The mid sections (spoiler area) have been either fine or rot sections. The lower tailgate vertical flange is also a rust trap/issue but this is generally dictated by the window and spoiler water ingress/access points.
When you have drilled the holes do:
o clean and rust primer treat the holes
o top coat the holes
o waxoil / similar treat the holes before fitting the spoiler
o fit spoiler
o waxoil / similar treat all areas after fitting the spoiler
Old 08-07-2018   #5
Sweden
Thanks for the advice,the car is from northern Sweden and is rust free,i'm a car painter by trade and will be giving it a full respray inside and out and then the whole car will be waxoiled.Do you happen to know the name or paint code of the red like this Abarth? Click image for larger version
Old 08-07-2018   #6
s130 has donated!
Think it is RACING RED 854
Being in the car painting trade you can mix up a small sample to check.
Thread Tools
(S) Abarth rear spoiler noel1978 500 14 13-05-2009 13:59
Abarth Spoiler Query - Fitment Insomnia FIAT Boo Archives 13 15-07-2008 14:47
Abarth Rear Spoiler Q's Scottemotive FIAT Boo Archives 16 09-06-2004 15:39
