Thread Tools
Old 29-06-2014   #1
South Africa
Fiat Strada EL 1200 Wiring issue
Hi All, Hoping there is someone out there that can assist. I have the 1200 Fiat Strada EL. For some time now I've experienced a problem with the indicators. When I have no headlights on or if I don't touch the brakes, They work fine. If I indicate and touch brakes they stop working. Also notice that when I hold in the brake pedal I get a low glow on the indicator bulb. Looks to me like a bad earth but don't know where to start. Any body with suggestions?
Thanking in advance
grsonline is offline Reply With Quote Quote
Old 04-07-2014   #2
flisko has donated!
Re: Fiat Strada EL 1200 Wiring issue
Quote Originally Posted by grsonline View Post
Thanking in advance
this looks excatly the same problem as i had on my punto mk1, turned out to be corroded and dirty rear metal bulbs holder, so the bulbs for the indicator wasnt making good contact with the holder so when you press on the brake they stop working, what i did was clean all the bulbs and their metal holders and problem went away
flisko is offline Reply With Quote Quote
Old 04-07-2014   #3
South Africa
Quote Originally Posted by flisko View Post
Hi flisko,
Thanks for the response had a look at the globes and holders but no visible corrosion present. Did however find a globe that had blown one issue fixed.. without even using the indicators ive noticed that when I turn on the headlights and press the brakes the fog light button on the center console lights up with out pressing it on. Weird issue this...to me it sounds as if a plug somewhere has corroded but cant seem to track it down.. Regards
Thread Tools
weird wiring issue in fiat seicento 900cc adrenaline I.C.E 1 06-06-2011 20:09
Fiat Punto Sporting 1.4 (2004) Wiring issue F4810 I.C.E 1 26-04-2010 22:48
(T) Fiat Punto Sporting 1.4 (2004) Wiring issue F4810 Punto (Mk2/2b) 0 26-04-2010 21:34
punto mk1 '96 1200 wiring diagram 126paul Tech Talk 0 08-10-2009 18:18
